I bought a '89 C4 about a month ago and a week or so ago i bought some fuel injection cleaner for it. i put it in and ever since then (even on another tank of gas) the engine will randomly shut off, even while i'm driving. Before I put it in the car had been running great without any problems at all (except the bolts for the hard top keep coming loose). Does anyone know what the problem might be?
also, my car usually idles at around 500-600rpm, is that normal?
89 has Multec's for the injectors, trash those things and get some new ones. Even if it is not the problem now, it will be the problem later. I do not speak from experience, I speak from already dropping the money so I would not end up standed.
Somewhat doubt the cleaner has anything to do with it. Intermittent stalls are a challenge and often lead to a lot of new and unnecessary parts, so you might start by getting something to capture some data with. A basic scan will at least show you if it's rich or lean, but I've got a feeling it's losing an important signal somewhere - either air (MAF) or fuel - reference from the distributor and without that, the injectors won't fire so it stalls just like you turned the key off. For 30 Bucks, I would try a new Module, but get some data first. With that, you can also know if the idle is within specs which are +/- 50 rpms from Targeted in Drive; +/- 100 rpms in Park/Neutral.
Never know, if it was really bad and the sludge got in the injectors or filter, then anything could happen... but i agree, filter first, then check the injectors, there are a bunch of posts and tech tips on how to test individual injectors. Go from there
There is a test I used on my '87 Lesabre to test the injectors. It was in the Helms manual. You take a screwdriver or similar tool and place the tip on the injector, you should feel it ticking or clicking while the engine is running. If not then it may be a bad injector. Its always good to hook it up to a computer and scan though to make sure.
What he said. I would think your using the cleaner and the symptoms appearing are a bit of a co-wink-e-dink. I'm getting from your post that she starts back up after the stall at some point right? Good luck, Larry
probably a co-ink-e-dent but I'd do the filter like suggested.
If that doesn't do it, you can have the ignition control module checked for FREE at Autozone, they need to run it through at least 10 cyles to get it hot, because they can test good until they get hot.
The first thing, as suggested above, is change the fuel filter. You will need a fuel pressure guage attached to the fuel rail to rule out this being a fuel problem. Tape the guage to your windshield while you drive and observe the psi when the engine "randomly shuts off". If the pressure drops, there is a fuel problem. It wouldn't hurt to test the ignition module, found in the distrubitor, at autozone...as Rick stated too rule out spark. Usually when these fail, it is when it gets hot...thus the 10 cycle test. The fuel filter is found on the passenger side under the car on the frame rail inline with the feed fuel line.
Since you state you only had the car a month, you might have a bad connection/circuit somewhere that hasn't shown itself until now and the injector cleaner was just a coincidence.
As for the hard top...more than likely a targa top, unless it's a vert, the threads/bolts might have become worn over the years from frequent use. And your idle is fine.
thanks for all the replies, i'm went today to get the fuel filter changed but it was $75 and i only had like $85 to my name, so i'm going to wait until i get paid again.
i know that the injection cleaner might be a coincedence, but i mean it did it the very first time like 5 minutes after i put it in, thats why i figured it must have been the injection cleaner, it seems like it was just to close to be a coincedence.
the car runs fine when i keep the rpm's up over 1000, it's just when i'm going slow or at a light or something and it's idling that it shuts off.
I've always heard not to use fuel injection cleaner because of what happened to you. So I have to disagre on the coincidence. Same reason you don't ever flush your automatic tranny and if you wait too long to flush the cooling systems you can run into problems.
I would still do the filter as suggested, you can get a filter for like $10 and do it yourself. It's a pain, but can be done right in your driveway.
Charles Probst, in his book on Corvette fuel injection, states that the multecs expose the coils to the fuel for cooling and that certan types of fuel injector cleaners (the solvent variety) can degrade the insulation on the coil wires.
