SES Question?
Old Jul 9, 2006 | 08:58 PM
CG77VETTE's Avatar
CG77VETTE
Default SES Question?
No codes stored so I threw in a new ignition module just because I had one on the shelf and still SES stays lit. Any suggestions? Thanks for any help. BTW, no recent mods.
Old Jul 9, 2006 | 09:39 PM
Hotred94's Avatar
Hotred94
SES usually means battery problem, alternator problem, or aftermarket radio transplant.
Old Jul 9, 2006 | 09:44 PM
RRT vette's Avatar
RRT vette
When you ground A and B terminal does the SES light flash? Or does it stay on all the time when driving or trying to pull codes?
Old Jul 9, 2006 | 09:45 PM
CG77VETTE's Avatar
CG77VETTE
Thanks for your reply. The battery is fairly new and charged regularly with a battery tender, the alternator was replaced last year and the radio has been in for 4 years with no ill effects. I guess the alternator could have gone bad but wouldn't the volts light come on if that were the case? I seem to remember that's what happened last year.
Old Jul 9, 2006 | 09:56 PM
RRT vette's Avatar
RRT vette
If the light stays on all the time, you have open/grounded circuit to the ECM.
Old Jul 9, 2006 | 10:36 PM
CG77VETTE's Avatar
CG77VETTE
The SES light flashes when pulling codes but stays on when engine is running. I don't know if it's related, but right before the SES light came on, I had the surging rough idle problem I had a few weeks ago. I changed the wires, plugs cap & rotor at that time and seemed to solve the idle problem because I drove about 200 miles with no idle problem at all. Could this be an intermittant EGR problem? Thanks for your help and reply.
Old Jul 10, 2006 | 06:55 PM
CG77VETTE's Avatar
CG77VETTE
Ttt
To SES Question?
