87 Changing Intake Gaskets
I'm planning on changing the intake manifold gaskets on my 87 in about 2 weeks. I'm going to do a total clean up on the intake, but was wondering if there is anything I should do/replace while I have the intake off. Thanks in advance for your replies.
Are you cleaning it up yourself or will you be bringing the intake to a shop to have them hot tank it ? Thats what I did with mine, Cost me $60 to have them clean it and make it look brand new before I painted it. They cleaned the intake manifold, runners, and plenum. Much better than having to spray it with chemicals then later try and wash it all off and take a risk of the paint flaking due to chemical reaction. Also I would recommend using Felpro for the gasket.
From: What do I know anyway? I'm just a 50 year old No0b
I ran my intake, plenum, and runners through the dishwasher about a half-dozen times and they cleaned up nicely (nice being single!). I would take the above advice and use Felpro gaskets and 'the Right Stuff' gasket sealer to make sure you don't have to do this twice. Now would be a good time to clean the throttle body and replace the thermostat too. Not too bad a job just take your time.
I planned on cleaning it up myslef, but your idea appears much better. I have a friend with a repair shop, but don't know if he has a hot tank. I will be sure to find out. I dont mind spending the money, I just want the best possible results. A couple of intake bolts had a very small amount of coolant around them, so I decided to change the gaskets. I know it is about 6 hours work, but we will make it last a few days to do anything else we find while we have it apart. Thanks for the fast response
I changed some of the Torx bolts out for Hex. This way you can use a ball headed Hex style tool to take off the runners. This allows you to remove the runners without removing the valve covers, A/C bracket, etc. Tear down time is so much nicer.
St. Jude '03-'04-'05-'06-'07
Gaskets, Right Stuff, vacume lines, vacume connectors, Hoses, belts, thermostat, drain and fill radiator (don't forget to burp her if you do). I did the same, took to a machine shop and had them Hot Tank them, best bet, then you can sand, wash, prime, and paint if you wish and it should work
Thanks for all the input, I am adding on to my list as the replies show up. I am checking into a local machine shop for the hot tank treatment. What type/color paint should I use? I want to keep that stock look, but want the new appearance.
Originally Posted by Joe C
DON'T PAINT! 10 years ago, i took my plenum, runners, alternator, smog pump etc off and cleaned and glass bead blasted all the aluminum components. i then got some PPG "chem film" solution from my local auto paint store (part number something like DX-701, 703, - ???) its for cleaning and sealing the pores in aluminum and comes in either gold tint or clear. i soaked the parts in the "clear" solution and after 10 years, zero corrosion. best of all, i didn't have to paint anything (except my valve covers), and it looks factory new. this winter, i'm going thru the same thing. i need to replace injectors, valve stem seals, and pull my intake (slight oil leak). anyway, i will have the intake hot tanked, and i will chem film before installation.
