Strange Headlight Problem
Old Jul 19, 2006 | 09:55 AM
SDS Photography's Avatar
SDS Photography
Default Strange Headlight Problem
The other night my girlfriend and I went to a sporting good store. The car was running great and everything was working. We come back outside and she goes "what is wrong with your headlight?" So I go look and low and behold my driver side headlight is flipped 70% over. So I go turn on the lights and the drivers side flips the rest of the way over and works but the passenger does nothing. The both light up but the drivers side will only reverse 70% back wards and the passenger side will do nothing.
anyone have any idea what could have caused this? or how to fix?
Old Jul 19, 2006 | 10:17 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you hearing the characteristic thunka-thunka-thunka-thunk noise four to six seconds after the headlight door closes?
If so, I'll lay odds your Delrin bushings in your motor gears are toast.
Old Jul 19, 2006 | 10:19 AM
Jet-Jock's Avatar
Jet-Jock
Try this:
https://www.corvetteforum.com/techti...D=16&TopicID=2
Old Jul 19, 2006 | 10:38 AM
SDS Photography
no it makes no noise at all, like it is not getting signal to the lights
Old Jul 19, 2006 | 10:42 AM
CJB's Avatar
CJB
Originally Posted by Jet-Jock
Bushings or motor! Or possesed!!
Old Jul 21, 2006 | 03:24 PM
SDS Photography
but they each have their own motor right? how often do both go bad? and why would the drivers side work but not go all the way down?
this is strange
Old Jul 21, 2006 | 05:46 PM
Jet-Jock's Avatar
Jet-Jock
GM used a gel material to spline the cam shaft to the motor worm gear. The gel dries up and crystalizes. It's worthless then. The repair is to open the motor up, remove the crystalized gel material, replace with Delrin bushings and grease the motor worm gear and reassemble.
One can go and then the other may follow a few months or years down the road. It's all dependent on how soon the gel crystalizes.
To Strange Headlight Problem
