hitting dashboard
Old Jul 21, 2006 | 11:26 PM
takovr's Avatar
takovr
Default hitting dashboard
Every once in a while, when I first start up my 86 vette my digital dash is blank. When I hit the dash-board it light's up and every thing is fine, I know this sounds like a dumb post or question but is this normal for a older car to do this ?
Old Jul 21, 2006 | 11:41 PM
topgunvette's Avatar
topgunvette
Old Jul 22, 2006 | 12:28 AM
jhammons01's Avatar
jhammons01
Are the Blinker signals and Bright light indicator real bright??
If so there is a short in your system. Search for a thread on how to fix it.
Old Jul 22, 2006 | 12:36 AM
takovr's Avatar
takovr
Default yes
Yes, blinker light's are bright and "High-beam" shows. I hit dash then everything comes on..
Old Jul 22, 2006 | 01:26 AM
jfb's Avatar
jfb
Let me type this yet one more time. The two circuit boards in the cluster plug together through a single row of pins on the front board into a socket on the rear board. The end pin closest to the center of the circuit board carries the backlight lamp current and an age relaxed spring on the socket causes connection resistance and the lamp current through this resistance causes enough heat to unsolder the pin. Resoldering the pin will not cure this problem. I fixed my 87 about 6 years ago by soldering a short piece of small insulated hookup wire from the pin to the socket and I have had no trouble with it since. Stop hitting the dash before you do some damage to the circuit boards!
The hi beam and turn signal lights come on because you have lost the ground connection to the cluster circuit boards and their ground current goes through these lamps keeping them on. Go here for some help with that problem: www.batee.com
Old Jul 22, 2006 | 02:12 AM
jhammons01's Avatar
jhammons01
OP, don't feel bad^^He yelled at me as well. It's because His heart is so big
Old Jul 22, 2006 | 02:35 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Had the same problem for a year until I read this DIY manual.
Old Jul 22, 2006 | 02:59 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Thanks for posting, now I don't have to ask. (Actually, I know how to use the search to find things. )
I do need to fix mine sometime though.
Old Jul 22, 2006 | 03:19 AM
topgunvette
To hitting dashboard
