C4 on fire
Old Sep 4, 2001 | 11:32 AM
Scott97's Avatar
Scott97
Default C4 on fire
A C4 caught on fire this morning in the Dell parking lot. :(
I don't have the digital with me or I would post some pics.
May this guys day get a WHOLE lot better!
Old Sep 4, 2001 | 11:48 AM
89AusVette's Avatar
89AusVette
Default Re: C4 on fire (Scott97)
Dang! PLEASE tell me it's not a yellow 96 LT4.....that would belong to Eric, the guy we partied with just the other night....what a suck way to start back to work! :( :( :( :( :( :(
Old Sep 4, 2001 | 11:55 AM
Scott97's Avatar
Scott97
Default Re: C4 on fire (89AusVette)
Nope, its white and I can't tell from here, but it looks to be an L98.
Old Sep 4, 2001 | 12:16 PM
89AusVette's Avatar
89AusVette
Well, still sucks to be him/her, but I'm relieved....thanks Scott!
Old Sep 4, 2001 | 03:59 PM
J Z06's Avatar
J Z06
Another C4 caught a blaze eh?
This keeps up,and I'm mounting a Halon Extinguisher on the passenger well. :mad
Old Sep 4, 2001 | 04:15 PM
Kale's Avatar
Kale
Default Re: C4 on fire (JD 90 383)
WHAT THE HELL IS GOING ON?
ANYONE WANT TO START A GROUP PURCHASE ON AN AUTOMATIC HALON SYSTEM????
:mad
Old Sep 4, 2001 | 06:44 PM
bogus's Avatar
bogus
Default Re: C4 on fire (Smash)
geez... I bought an extingisher a LONG time ago...
Old Sep 4, 2001 | 07:00 PM
BobMachus's Avatar
BobMachus
Default Re: C4 on fire (bogus)
It'll just burn up with everything else unless you have an automatic system. I'm with Vash & co, automatic halon in the passenger compartment.
Bob
Old Sep 4, 2001 | 07:01 PM
Arisa's Avatar
Arisa
Ain't that the truth !!!!!!!!!!!!!!! Mounted to the front of the driver's seat. It's halon too! I am a little paranoid about fires anyway. Got two big C02's in the garage along with a 20lb halon, a 5lb Halotron in the kitchen & a 2.5lb halon in the computer room.
Neal
Old Sep 4, 2001 | 07:13 PM
90 Corvette ZR-1's Avatar
90 Corvette ZR-1
Default Re: C4 on fire (Arisa)
Arisa:
Do the Z06 rims stick out @ all, do they rub, did you have to do any mods to make them fit
Old Sep 4, 2001 | 09:21 PM
vettenuts's Avatar
vettenuts
Well people, keep an eye on your fuel lines that run from the fuel rail to the first joint under the floor. The rubber sections drys out with age and will fail. When it does, there is 40 psi or more fuel pressure to spray it all over the exhaust, with these types of results. And guess what, GM no longer makes replacements. I have stated this a number of times, this is the biggest problem facing C4 owners, and most are not even aware of the pending problem.
Check those lines, the rubber section is "U" shaped and just in front of the block on the passenger side.
Old Sep 5, 2001 | 08:36 AM
Stv50's Avatar
Stv50
Sad news. Any ideas on how this could happen. Sure would like to know to head off any problems.
Old Sep 5, 2001 | 09:19 AM
gh86E's Avatar
gh86E
Default Re: C4 on fire (vettenuts)
Try dropping your gas tank - you''ll discover severely rusted fuel lines that you didn't even know about. Water must get up into there and not dry out. The lines can even look pretty good under the car. But up in front of the tank, where you can't see from underneath, it's a different story.
Old Sep 5, 2001 | 11:19 AM
GTB's Avatar
GTB
Default Re: C4 on fire (gh86E)
:eek:
I had no idea!!! Thanks for the heads up, I'm gonna have mine checked out and I'm going to get an extinguisher anyway!!
Old Sep 5, 2001 | 12:51 PM
Arisa's Avatar
Arisa
Default Re: C4 on fire (90 Corvette ZR-1)
Arisa:
Nope! They fit better than great! No mods at all, I even used the factory lugs off my car. Please note I used 17x9.5" all around. I am going to 285's later want to be able to rotate the tires. I seem to be wearing the rears out faster than the fronts for some reason. Maybe I should get it looked at ? :D
Neal
Old Sep 5, 2001 | 02:13 PM
GlockLT4's Avatar
GlockLT4
Same here.. I always carry an extinguisher with me... just in case.
Old Sep 5, 2001 | 11:24 PM
bluevette87's Avatar
bluevette87
just went out and checked mine,it is in good shape :cheers:
To C4 on fire
