transmission fluid
Old Jul 29, 2006 | 11:28 PM
byedan's Avatar
byedan
Default transmission fluid
today i used a pump and sucked out a gallon of trany fluid then topped it off with new fluid will this help if i do this about every two weeks till the fluid is clean. then i am going to get a filter and pan replaced. also i added water wetter to it today. i will let you all know how this works
Old Jul 30, 2006 | 12:07 AM
Wayne88's Avatar
Wayne88
Why don't you just get the tranny fluid changed ???
The Water Wetter [IMO] is one thing on the auto parts store shelf that really works.
Old Jul 30, 2006 | 12:27 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
[QUOTE=byedan]today i used a pump and sucked out a gallon of trany fluid then topped it off with new fluid will this help if i do this about every two weeks till the fluid is clean. then i am going to get a filter and pan replaced. also i added water wetter to it today. i will let you all know how this works[/QUOTe
OK; here`s how I did it in my `87. First changed the filter, & pan gasket. then I disconnected the top tranny cooler line at the radiator, & hooked up a piece of vinyl tubing to that line.I then SECURED the tubing to a empty gallon container ( Its better if you can have another person to hold the tubing in the container-ask me how I know ) After you do that, pour a gallon of new fluid into the trans, & start the engine. Let it idle. The old trans fluid will come out the tubing into your container. When the container fills up, shut the car off, dump the container, pour another gallon of new fluid into the trans, & do it again, until clean fluid comes out of the tubing into the container.Since you have the cooler line disconnected, the dirty fluid cannot go back into the trans. It can only go into your container. Easy HUH?
Old Jul 30, 2006 | 12:51 AM
skeet's Avatar
skeet
If you plan on keeping the car I would bring it to Chevy along with 15 quarts of Mobil 1 synthetic ATF Dex IV (newest ATF out) and have them exchange all 15 quarts.
Old Jul 30, 2006 | 07:09 PM
93 ragtop's Avatar
93 ragtop
My wife has a 2004 honda pilot. According to the owners manual, the proper way to change the fluid is buy 12 qts. , drain 3 and refill, do this 3 times to flush the transmission. Now the total fill is 8 with the converter and we all know you can only drain the pan, which is 3. Do the math and doing this 3 times pretty much gets all the old fluid out.
IMO what you are doing is fine. Also, this is basicially the same way alot of us change the power steering fluid.
Old Jul 30, 2006 | 07:55 PM
Aardwolf's Avatar
Aardwolf
It's soooo easy using the top oil cooler line at the radiator!!!
Old Jul 30, 2006 | 08:31 PM
lusor's Avatar
lusor
Can I do this to a 95 ?
Old Aug 1, 2006 | 04:06 PM
Aardwolf's Avatar
Aardwolf
I have done that on my '88 but I don't have a '95. Press the other tab up top, then goto tech tips. There is a tech tip of it that explains a lot. On my car the fitting is right on top of the radiator by the coolant cap.
Old Aug 1, 2006 | 04:42 PM
byedan's Avatar
byedan
my concern with the top cooler line is you are still running the tranny low on fluid i understand not under a load but still i would start my car with out a oil filter to drain the oil pan
Old Aug 1, 2006 | 05:24 PM
kenv's Avatar
kenv
St. Jude Donor '10
You are not running the trans low on fluid. You are only taking out 4 quarts at a time, & that is the dirty fluid. I don`t have the book in front of me right now, but the trans holds a lot more than 4 qts with a complete drain
Old Aug 1, 2006 | 06:18 PM
Aardwolf's Avatar
Aardwolf
You can do two quarts at a time if you'd like to as well. When I did this I counted to ten while the car ran. I think that pumped out three quarts. I didn't want the jug to overfill.
Old Aug 1, 2006 | 10:55 PM
byedan's Avatar
byedan
even though you are not running the trans dry you are running it low on fluid and if think a engine does not like low oil pressure or a lack of oil i can promise you that a auomatic transmission is a lot more touchy. not trying to start a fight i am just saying that using the trans line method does not sound like a very good idea to me
Old Aug 1, 2006 | 11:45 PM
JrsTurn's Avatar
JrsTurn
I'm sure there's a math major out there that can tell you how many quarts of new fluid it will take to make old fluid clean even tho you are mixing good with bad. I'm no math major but my guess is alot. Why not just take it somewhere and have it flushed and filled along with a new filter? Good luck.
Old Aug 2, 2006 | 12:58 AM
newbecorvetteguy's Avatar
newbecorvetteguy
[QUOTE=kenv]
I did this too only I started out disconnecting the top cooler line and pumped out a gallon. That way the pan was already pretty empty when I went to remove it. IMO there is no harm that can be done from low fluid doing it this way. The tranny is a lot more empty than that when it's assembled or overhauled and first filled.
Old Aug 2, 2006 | 09:20 AM
byedan's Avatar
byedan
yes you are correct about the transmission being empty when it is rebuilt but you also do not start the car untill you install transfluid so it just pumps the fluid up to where it needs to be and the last time i installed a tranny we filled the converter with fluid before we started the car
Old Aug 2, 2006 | 09:21 AM
byedan's Avatar
byedan
we filled the converter before we put it on the transmission and installed the unit in the car
Old Aug 2, 2006 | 10:00 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Why not take it to a transmission shop and have it powerflushed? They have a machine that sucks out all the old fluid and replaces it with new fluid. You should have the filter replaced, too.
Old Aug 2, 2006 | 12:29 PM
GKK's Avatar
GKK
To answer your original question:
Yes, your method will work just fine. Other members are just trying to inform you of a much easier and efficient method which has been performed flawlessly numerous times by others including myself for years.
Professional power flushing of your transmission will do more harm than good if your transmission has a lot of miles on it and is not recommended by many experienced transmission shops.
Also, according to my 1991 owners manual, automatic transmission drain and refill capacity is 10 pints or 5 quarts, a complete transmission overhaul is 22.4 pints or 11.2 quarts. Yours should be similar.
Old Aug 2, 2006 | 01:24 PM
byedan's Avatar
byedan
thanks guys i do not like the idea of a power flush. and i do not like the idea of the transmission being run low on fluid even not under a load but you know what your way does sound pretty simple just not for me. not trying to start any thing just telling my opinion
To transmission fluid
