loose glass
Old Aug 1, 2006 | 10:41 PM
scottiesc4's Avatar
scottiesc4
Default loose glass
Before I get to the subject I would like to thank everyone who has answered my questions in the past, anyway on my 84 side mirrors the glass is becoming loose, ecklers has a trunion that they say fixes this problem and hopefully it is the problem. How do you get the glass away from the old trunion in order to fix this problem ? THANKS ! scott
Old Aug 1, 2006 | 10:46 PM
Jet-Jock's Avatar
Jet-Jock
Pull gently.
Old Aug 1, 2006 | 11:27 PM
copperhead55's Avatar
copperhead55
I had the same problem and the after replacing the trunion I found the motor mount was loose. I used some loctite and remove the whole assemble on each side and fixed it for good. If you need the complete instructions please just PM me with an email address.
I got my help from Da Mail Man he was great!
- Randy
Old Aug 2, 2006 | 12:32 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
My '88 had both mirror glasses rattling every time I shut a door. I was able to stop it by tightening the small phillips screw(s) you can see inside the housing behind the glass when they're adjusted all the way up.
Old Aug 2, 2006 | 10:22 PM
scottiesc4's Avatar
scottiesc4
Default we have the problem solved
Thanks for all of your input, I found the trunions are fine the problem is that the lower clips on the back of the mirror housing that hold the mirror to the trunions are broken, so I'm not sure what to do at this point. so I think I am going to have to find some new glass for this problem.
Old Aug 2, 2006 | 10:31 PM
Jet-Jock's Avatar
Jet-Jock
Order new trunions. 34177 $3.99 from Ecklers. "The trunion snaps onto the back of the glass which in turn mounts to a black plastic pivot."
To loose glass
