91 Brake Problems
Old Aug 14, 2006 | 08:51 AM
jmyokley's Avatar
jmyokley
Default 91 Brake Problems
The brakes on my 91 take a lot of effort to push and it feels like the car will not stop. I pulled the wheels off and there is not any leaking in the calipers. What could be the cause? Bad booster?
Comments appreciated.
Old Aug 14, 2006 | 10:04 AM
polo91cnvt's Avatar
polo91cnvt
jm,
You maybe right, check to see if you hear any hissing sounds from the booster. You will hear them as the car is running or when you push in the brake. If not check the vacuum coming from the engine to the booster. No vacuum you could have a vacuum leak and thus no power to the breaks.
Polo
Old Aug 14, 2006 | 10:31 AM
jimmers's Avatar
jimmers
Usually when the brake booster starts to fail the brakes will be really hard to push. It will get worse over time.
Old Aug 21, 2006 | 09:40 AM
90EXPVette's Avatar
90EXPVette
I'd bet it's your booster. I had the exact same issue and just replaced it. You can get a replacement from Autozone for $99 including a refundable 20 core charge.
To 91 Brake Problems
