Great optispark picture!!
Old Aug 18, 2006 | 03:34 PM
stouk's Avatar
stouk
Default Great optispark picture!!
For the guys that need to know. This helped me understand where the optispark is located. Go to sonomacrew01's corvette pictures, he has an engine out of car photo that will show you exactly where it is.
Thanks sonomacrew01
http://forums.corvetteforum.com/phot.../ppuser/172071
Old Aug 18, 2006 | 04:00 PM
Great White North's Avatar
Great White North
Boy,I wish I had one!!! Not.
Old Aug 18, 2006 | 04:05 PM
CSS996's Avatar
CSS996
Sorry, I didn't see the opti... I was too busy staring at the 505s.
NOICE!
Old Aug 18, 2006 | 04:48 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here are some I took at the NCM. Shows how the wires are routed too.
Old Aug 18, 2006 | 04:51 PM
corvetteronw
Cruise-In VIII
More:
Old Aug 18, 2006 | 04:54 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I sure bet those engineers where happy with them selfs when they designed that. I know I would have been. It's a pretty ingenious design...until you get it wet.
Old Aug 18, 2006 | 04:58 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I love the LT1.....not too fond of the Opti though.
Old Aug 18, 2006 | 09:22 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Until you've taken the front of the engine apart, it's just an act of faith to believe it's there. I'm not complaining though. I replaced the original at 93K miles because I had the engine torn down. It was still performing well though, as is it's replacement at 25K miles of service. It's still by far the most effective and ingenius distributor ever installed on the SBC.
Old Aug 18, 2006 | 10:45 PM
C4boy's Avatar
C4boy
I gotta ask (seriously, because I know zilch about optispark)....How can it be the most effective and ingenius SBC distributor ever designed if there are so many problems with them? Not to mention the cost of replacement. Just one look at it's placement in the motor and I'm scratching my head asking, what were they thinking?
Old Aug 18, 2006 | 10:54 PM
dudman's Avatar
dudman
This is about enough to scare a man to death. Did they eliminate this situation with the C5 LS1?
Old Aug 18, 2006 | 10:56 PM
Drew M's Avatar
Drew M
has anyone ever tried that replacement system from MSD?
Old Aug 18, 2006 | 11:01 PM
Corvette Kid
Admittedly, the earlier ones were more troublsome. But for the most part, those shortcomings were cured with the later version. Even the early ones can be improved by adding the venting system designed into the second version. The location? Maybe not as accessible as a top mounted distributor but much more stable than running off of the rear of the cam. Yes, cams twist. Some cams are even ground to compensate for this at higher RPMs. What other SBC distributor can you name that can time individual cylinders as needed to prevent spark knock? No, it's not perfect. But I consider it to be an amazing piece of engineering for it's time. And there are many other parts of my engine that I worry about more than my opti-spark.
Old Aug 18, 2006 | 11:20 PM
C4boy's Avatar
C4boy
(in best Carson voice) I did not know that.
Old Aug 19, 2006 | 01:23 AM
Arkybill's Avatar
Arkybill
I've got to agree with "the best design for a SBC". Yep, with 2 knock sensors (one on each side of the block) the 'puter can (and does) time each cylinder as needed. That's where the good gas milage comes from (IMHO).
And, IF the seals are still ok, it don't matter if the Opti gets wet. Hey, if the engine is warm, it'll dry off real quick. The old GM HEI ignition was very expensive ($175 just for the plug wires in 76) to work on.
I figure any thing that'll go to 100 K or so miles with no maintance, ain't no slouch.
Old Aug 19, 2006 | 07:40 AM
sonomacrew01's Avatar
sonomacrew01
don't go by that picture. That opti was defective, and it was brand new! Everytime I look at that picture I get upset because only if I knew the opti was bad, it would have been real easy to replace.
I have the MSD now, 400 miles and no problems. Had a couple dyno runs where it pulles 5500 rpm's no problem. No sense in going any higher when the engine reached its peak.
Old Aug 19, 2006 | 10:03 AM
Bigredwing's Avatar
Bigredwing
Default Make Ron's NCM Pictures a Sticky!
I make a motion that Ron's pics be made a sticky. They instantly answer about five forum posts per week. Maybe he should get a residual?
Old Aug 19, 2006 | 11:32 PM
corvetteronw
Cruise-In VIII
I like this guy!
Old Aug 20, 2006 | 08:22 AM
Casethecorvetteman's Avatar
Casethecorvetteman
There is not "so many problems" with them really, its more the fact so many people like to point the finger at it every time their LT1 fails to run smooth and strong. Go and grab a hose and spray any distributor hard enough and its going to kill it no matter where its mounted. Abit of know how and abit of common sense go a long way
too
There is nothing much wrong with it at all really, its a bloody good system.
To Great optispark picture!!
