Screw in tire - Plug or Replace
Old Aug 23, 2006 | 12:20 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Patch it
It will be fine
No plugs
Old Aug 23, 2006 | 12:29 PM
Wayne88's Avatar
Wayne88
Originally Posted by CREWZIN
I had a couple of plugs on my old tires. The shop I used said the plugs they use are for high speed low profile tires. Were they lying They took the tire off the wheel and sanded down the spot where the hole was. Put fast drying glue on the hole. Then they took a plug with a two inch diameter flat end and pushed it throgh the hole till the flat end matted down into the glue. The plug filled the hole and the flat end sealed the inside of the tire. Never had a problem with that kind of plug at any speed.
That's what I did. Those 'mushroom' plugs are the best.
Its a patch and a plug combined.
Old Aug 23, 2006 | 12:35 PM
96RedRoadster's Avatar
96RedRoadster
It's at Goodyear right now - $25 for the patch.
Thanks again everyone.
Dion
Old Aug 23, 2006 | 05:52 PM
aminnich's Avatar
aminnich
Originally Posted by BADDUCK
What do you think smart ***? Why don't you just give your answer rather than picking apart someone elses answer? I hate that!
I had already given my answer, which is to patch and plug. The plug helps seal the puncture and the patch helps re-enforce the 'injury'. Both are important. A patch alone still lets water penatrate into the casing and can cause the steel belts to rust and then a tire failure.
The patch helps insure the repair will not leak, re-enforces the casing and even better should be 'painted' with some secure coat to help ensure that the tire flexing does not cause any separation.
Now as far as the "smart ***" I did not mean to insult you in anyway, but obviously did. Please accept my sincere apologies. My purpose on the forum is to learn what I can and share what I know, not to cause any discomfort to others. Hopefully we will be firends down the road.
Thanks,
Andy
