Screw in tire - Plug or Replace
I don't like the idea of having a plug, especially on a front tire. The Kumho's have less than 10k on them. I guess it would be a good time to go ahead and get new rims as well. ARGGH!!!
Any plug fans out there?Does any one know of tire shops to absolutely avoid or any to recommend in Miami - it would be appreciated (unless I buy online). When I purchased my C4 the wheels were on the wrong spots (bigger rear wheel was mounted on front!
Do you have low aspect ratio, high performance tires on the Grand Cherokee and occassionally more than slightly exceed the speed limit?
Meaning not all tires are equal in either construction or application.
They took the tire off the wheel and sanded down the spot where the hole was. Put fast drying glue on the hole. Then they took a plug with a two inch diameter flat end and pushed it throgh the hole till the flat end matted down into the glue. The plug filled the hole and the flat end sealed the inside of the tire. Never had a problem with that kind of plug at any speed.
Then, there's the also old but newer style of get some thick, gooey "thread", put it through a huge "needle" and stick it in the hole from the outside of the tire. Not always very safe, sure, or certain. The only certainty, imo, is DON'T. Don't use it, unless to get you home a very short distance.
Finally, there's the "new", which is a plug and patch all in one. It works, it's very good and I'd recommend it, again with only some exceptions.
Hopefully, your/a 10K mile tire isn't used up. To be ultra-safe, replace the tire (in axle sets), however, this can get to be ultra-expensive.
At anything less than all out driving and/or high speed (illegal) street driving, if the hole is relatively "mild" and relatively well-placed (there is really no such thing as a well placed extra hole in your tire, I understand), I'd go with the third type of repair.
And, will you stop getting "screw-ed"!!!
If it's used for cruising, normal highway trips, and commuting, patch or plug it and you'll be fine.
We plug the tires on the rent cars (assuming the damage is in the middle of the tread, not near the sidewalls) and have never to my knowledge had a plug related tire failure. And these cars get beat on.
The screw is in the tread area about 1 1/2 to 2 inches from the side.
I use the tire to get up to the speed limit quickly but occasionally lose situational awareness and have been shocked to find myself in triple digits.
The tires are definitely still in good shape so I will look at a patch and refrain from higher speeds until I replace.
As for plugs, I have never had one come out, ever. Been driving for 35 years. My pickup has four plugs in the right rear tire. Been in there for two years. (ran over the same nail twice
) That tire stays on the rear just in case. If I was in your situation I would go for the patch/plug as long as the hole is in the tread.
