Need some help replacing my Bose system
Old Aug 23, 2006 | 11:06 PM
topgunvette's Avatar
topgunvette
Default Need some help replacing my Bose system
////owered by the head unit, thanks
Old Aug 23, 2006 | 11:14 PM
richdwyer's Avatar
richdwyer
I ran new speaker wires to the back speakers. The stock blose wiring is too light of gage for quality sound. I also put some speakers in the dash where the grill covers are. I just bought a set of non-bose speaker grills and mounted after market speakers in them. I didn't like the way the door speakers sounded. I can't remember if they were 6x9 in the back or not, but I believe they are. One thing I did not do when I upgraded the stereo was put a switch on the antena so I could turn it off when I just listen to cd's (which is most of the time).
Good luck. RIch
Old Aug 23, 2006 | 11:37 PM
topgunvette
Old Aug 23, 2006 | 11:43 PM
vader86's Avatar
vader86
http://forums.corvetteforum.com/show....php?t=1416799
Old Aug 24, 2006 | 12:02 AM
topgunvette
^^^ just read that whole post and im confused as hell lol... i want the easiest method possible pretty much... i read 5.25's will fit in the stock enclosures so maybe that is my best bet?
Old Aug 24, 2006 | 01:00 AM
vader86's Avatar
vader86
5.25" in the doors, 6.5" round in the rear, new wiring, new head unit
thats all you need
Old Aug 24, 2006 | 01:38 AM
K87ZZ4's Avatar
K87ZZ4
I agree with Vader86 on the 5.25s in the doors, but I dropped 6x9's into the rear (although they were a more shallow speaker; another brand wouldn't fit). If I remember right, the rear speaker boxes come out pretty easily.
There are amps built into the speaker boxes in the doors (behind the 4" Bose speakers). If you don't pull the speaker boxes, you will have to run wires through, or around them. You CAN get the speaker boxes out of the doors, but it can be a bit tricky.
I assume if you want to go simple, that you are going to rely on deck for power to the speakers.
Best of luck (to your buddy, anyway
Old Aug 24, 2006 | 04:19 AM
topgunvette
Old Aug 24, 2006 | 09:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
With a little work, you can drop in 6.5'' in the front. I have JL 8'' subs in the factory rear locations and Infinity 6.5" in the front. Me like
Old Aug 24, 2006 | 12:18 PM
topgunvette
///////ume, plug n play?
Old Aug 25, 2006 | 08:30 AM
AGENT 86's Avatar
AGENT 86
Originally Posted by vancityguy
and with no work 5.25's all around?lol... maybe ill just install the head unit on my own and take the rest to a shop and get it all done in one shot... the new head unit goes in the same way my old aftermarket one does i assume, plug n play?
If i remember correctly, the rear mounting flange looked like it would accomodate a 6x9. As for plug and play, maybe if you were mounting the same brand. Most makers will have their own style of connector, so you will probably have to rewire, matching their info to the factory wire info.
http://members.shaw.ca/agent86/Radio.pdf
Old Aug 25, 2006 | 09:50 AM
tarheelracer's Avatar
tarheelracer
I put 6x9's in the rear and they fit like stock once you take that huge bose enclosure out. I also put 6.5's in the doors. They fit perfectly. If the magnet on the back was any thicker they would've rubbed up against the windown.
Here is my complete decision process through instillation of when I dumped my Bose last summer. I hope it helps.
http://forums.corvetteforum.com/show....php?t=1114953
Old Aug 25, 2006 | 01:05 PM
topgunvette
well yesterday i replaced my aging old pioneer head unit with a jvc kdlh810 mp3 deck and am pretty happy with it, i've still got the crappy bose speakers but once i figure out what type of speakers to get i will rewire everything and ditch the bose but for time being i have static coming through the speakers still, does anyone know how i can get rid of it?
Old Aug 25, 2006 | 02:14 PM
90steelblue's Avatar
90steelblue
did you rewire the speakers? sounds like you tied into the stock wiring with the new head unit. Each bose speaker has an amp mounted to it. if the amp goes, that's when you usually hear the static. bypass that amp and you should be listening to some clear tunes.
Old Aug 25, 2006 | 02:23 PM
topgunvette
your right i didn't get it rewired... can i just bypass the amps and power the bose speakers with my deck power?
Old Aug 25, 2006 | 02:29 PM
90steelblue
i'm sure you can.. don't know how it'll sound though. I'm pretty sure the stock bose amps run at like 1 or 2ohms to up the ante on the wattage output.
give it a shot.. If it doesn't work out, just add some new speakers.
Old Aug 25, 2006 | 02:50 PM
topgunvette
^^^ it is something i will tackle sometime soon i mean the speakers sound okay right now but i would like some better sound but the static is just annoying as hell when the volume is low
To Need some help replacing my Bose system
