a/c troubles
Old Sep 4, 2006 | 10:53 PM
greenwoodc4's Avatar
greenwoodc4
3rd Gear
Default a/c troubles
hey everyone im having trouble with my a/c i did a retrofit to 134a and now my blower motor won't work i have replaced the rotary switch in the dash and the relay and still nothing. any ideas would help greatly thanks
Old Sep 5, 2006 | 01:11 AM
aminnich's Avatar
aminnich
Assuming the compressor clutch is engaging then problem is in the motor circuit, including the motor. Also assuming you have good fuse and power to the switch, power to the relay. Unplug the harness at the motor and use jumper + and - wires directly to the motor. Motor runs? Check power from the harness and same for the ground side.
Old Sep 5, 2006 | 07:23 PM
greenwoodc4
3rd Gear
the blower motor checks out and the wiring does to i got the blower to work but now all i have is low speed
Old Sep 5, 2006 | 11:04 PM
aminnich's Avatar
aminnich
I don't have a schematic, but there is likely a little resistor in the circuit that has gone bad.
Old Sep 6, 2006 | 06:58 PM
greenwoodc4
3rd Gear
there is a resistor on the evaporater i'll try that next
To a/c troubles
