Tranny Leaking
Old Sep 5, 2006 | 09:15 PM
papafrancisco's Avatar
papafrancisco
Default Tranny Leaking
I noticed some red drops on my garage floor. It appears to be coming from the rear end of the transmission. Has anyone tried using a stop leak of sorts? Is it worth the money? I know we're only talking a couple of bucks or so. Thanks
Old Sep 5, 2006 | 09:20 PM
papidos's Avatar
papidos
I personally would never use a stop leak for anything on my vehicle, engine tranny or cooling system. That could be the most costly few bucks you ever spend. Find the leak in the tranny and see what you can do to fix it. There's a vent on them so if their overfull they may leak from the vent. They also may leak from the vent if they get too hot.
Old Sep 5, 2006 | 09:39 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Get some Lucas tranny stop leak. My boss's van developed a pretty substantial leak, so before i tore into it, i tried Lucas. All i can say is WOOOOOOOOOOOOOOW. That $hit works.
Old Sep 5, 2006 | 10:27 PM
Muffin's Avatar
Muffin
I am not a big fan of stopeaks of any kind. If used according to the directions I don't think they will hurt. I,for one, wouldn't take the risk.
If your leak is at the very back of the trans it is most likely the output shaft seal. That is not a big job at all.
Old Sep 6, 2006 | 07:47 AM
Pete K's Avatar
Pete K
The additives in stop leak are designed to soften and swell rubber seals in hopes of stopping the leak. I too would rather see you change the part that is leaky. If you are tempted to pour in a can of miracle cure, only use 1. More is not better. I can recall a few transmissions that I overhauled that had a few cans added. The o-rings turned into what looked like overcooked noodles. In those cases, stop leak killed the trans dead.
To Tranny Leaking
