Replacing Water Pump, Quick ???
Old Sep 9, 2006 | 08:15 PM
Idareu's Avatar
Idareu
Default Replacing Water Pump, Quick ???
Ok, I've prepping the new water pump to go into the car but I can get this sensor off the old pump. Can someone give me the "correct" name and maybe a possible OEM part number in case I'm not able to get this one off.
I've got a free round of virtual beers for the answer...
Old Sep 9, 2006 | 08:31 PM
wrw7255's Avatar
wrw7255
Coolant temperature sensor
Old Sep 9, 2006 | 08:35 PM
Idareu's Avatar
Idareu
Thanks!!!!
I'm hoping that one of the parts houses here in town will have one if I can't get this one off.
As promised...
Old Sep 9, 2006 | 08:46 PM
wrw7255's Avatar
wrw7255
Your very welcome. Just changed my water pump on my 92 recently. It wasn't as hard as I thougth it might be. Good luck.
Old Sep 11, 2006 | 10:24 AM
SJW's Avatar
SJW
wrw7255 is correct, but be aware that the LT1/LT4 engine has two temp sensors, so if you're requesting a new one at the parts counter, be sure they know it's the one in the pump that you need.
The sensor in the pump feeds Engine Coolant Temperature info to the ECM, which uses it for engine management as well as to drive the digital temp readout on your Instrument Panel.
The other sensor (in the cylinder head) feeds the analog ECT gauge on your IP.
Be well,
SJW
Old Sep 11, 2006 | 10:45 AM
Idareu's Avatar
Idareu
Be well,
SJW
I found that out the hard way. I didn't know the difference and neither did the parts puller at Advance Auto Parts. Luckily for me Central Auto Parts were a bit more knowledgeable and were able to get me the right one. I'll be putting it in tonight if all goes well.
Thanks again guys for all of your help. Hopefully tonight I'll get the Vette fired up and all will be well.
To Replacing Water Pump, Quick ???
