shifting into reverse
Old Sep 13, 2006 | 12:51 AM
coltacp's Avatar
coltacp
Default shifting into reverse
I have an 88 with the 4+3 transmission. When I shift into reverse, the gear does not mesh and I hear grinding. The only way to aviod this is to place the transmission into reverse before starting the engine. Is there a problem with the transmission? Thanks in advance.
Old Sep 13, 2006 | 01:15 AM
ncook's Avatar
ncook
Mine does the same thing on occasion. Synchronizers?
Old Sep 13, 2006 | 08:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If this is a recent problem, check your clutch fluid level. Reverse gear can be very fussy.
Old Sep 13, 2006 | 08:59 AM
AILERON's Avatar
AILERON
Before doing anything else, check your clutch fluid.
Old Sep 13, 2006 | 10:04 AM
RonVette2's Avatar
RonVette2
I agree with above check those things, also I have found in the past that while stopped and about to go into reverse, shift into 1st first, once in 1st gear and still stopped with one foot on the brake and other on clutch. go directly from 1st to reverse in one move like you were shifting from 1st to 2nd normally, and you should have no issue, that has worked for me. Let us know how it goes, go and try it out now
Old Sep 13, 2006 | 10:48 AM
c4cruiser's Avatar
c4cruiser
Grinding going into reverse can also be an indication of a work clutch disc. The C4 hydraulic clutch assembly is not adjustable so any wear on the disc impacts the release point. How many miles oin the clutch?? I would bet that your clutch is about gone.
Other possibilities are a bad throwout bearing or the clutch arm (fork) is bent or worn.
Old Sep 13, 2006 | 10:54 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
While this may not be the prescribed method, even new trans/clutch setups can have a degree of difficulty when going from forward gears into reverse. For that reason, it may sound like a pain, but ronvette is correct: shift into 1st gear, first, and then push it into reverse. I can't recall if this is still the case, but 1st and reverse in some cars used to be on the same shaft and 1st has a synchronizer whereas (?) reverse doesn't.
Old Sep 13, 2006 | 11:32 AM
Grenkepr's Avatar
Grenkepr
Old Sep 13, 2006 | 01:16 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Let out the clutch in nutral before going into reverse. Then shift into reverse. This is what I do in my dad's 87 with this same problem.
Old Sep 13, 2006 | 02:01 PM
tarheelracer's Avatar
tarheelracer
Mine has always done it. There is nothing wrong with it. I would never grind it, but every mechanic that touched my car would grind it when he was shifting it. I would simply put the car in first, then quickly shift from 1st to reverse and nothing would ever happen. Try that out.
Old Sep 15, 2006 | 02:01 PM
coltacp's Avatar
coltacp
Default Shifting into reverse
I tried shifting into 1st then into reverse and it worked very smoothly. Thanks to all for the help.
Old Sep 15, 2006 | 02:13 PM
redrose's Avatar
redrose
reverse gear does not have synchro mechanism....factory spec is to depress clutch and wait 10 seconds for trans gear train to coast to a ''near'' stop...if you don't like the factory waiting period, depress clutch, engage high gear (least synchro wear) momentarily to stop gear train rotation and then engage reverse gear quickly but do not ''jam'' into reverse, allow oil drag in trans to rotate reverse gears to alignment.
Old Sep 15, 2006 | 05:36 PM
85 500 horse's Avatar
85 500 horse
Shifting into either 1st or 2nd gear prior to shifting into reverse should work fine. And when doing this, do not shift quickly. Make an exaggerated slow shift. This gives everything a bit longer to mesh properly. I used to have the same problem you're experiencing and as soon as I began to do as I described herein, all ill effects disappeared.
To shifting into reverse
