air filter help!!
I too am interested to see how it runs/drives without a MAF.
You mean you could actually DRIVE the car with the MAF removed????!! I could see that it might START, but to actually DRIVE it amazes me.I'll bet when it warmed up, it would be an interesting experience.
Larry
code5coupe
It and your O2 sensor are two that you cant do without.
How does it run with no maf
You MUST have the MAF on it to work properly. This measures the amount of air going into the car, without it, it basically just goes into limp mode because it can no longer measure the air flow, which is what the computer needs to calculate how much fuel, etc to use.
I think this might be what you want to do instead if you are going that route.
Here is mine:
Goto Lowes/home Depot in the PVC pipe isle and pickup a 4" to 3" reducer, clamp that between the TB and MAF, then just clamp a 3" opening cone filter to the MAF.
Just be warned, the entire forum will make fun of you. Everyone will say "hot air blah blah, wont don't anything over the stock intake blah blah, you test it and let us know that it wont work and we were right blah blah" yet nobody has yet to show me any testing they have done themselves to show if I was right or wrong.
Either way I don't care, I like it and it's my car.
Here is mine:
In theory a CAI should make a good bit more power but theory and reality aren't always the same thing. Having raced many cars over the years I can tell you that IN MY EXPERIENCE going from a stock airbox to a CAI made a big difference but going from the CAI to something similar to what you did (filter on the TB) had no noticable change in power.
If people want to complain they are arguing theory. I doubt anyone here can provide tangible empirical data supporting a claim that a high-flow filter clamped to the throttle body makes less power than a CAI because no one has tried both on a dyno or dragstrip. They take their stock airbox out, put on a CAI and feel a big difference so their minds are set. End of story.
A side note on your statement... i think that another reason that the CAI's people install create more flow is because 95% of the time, its a single pipe that replaces a huge box, lots of tubes and hoses, etc on most cars. My tiburon's for instance.. I had an ENTIRE trash bag full of parts I removed from the intake. The final intake opening itself once I found where it sucked in the air was roughly smaller than the size of my fist. Then it wound all over the place, into several resonators, then to the filter box, then finally to the motor.
So I would say most of the gains from a CAI come from the fact that you are replacing all the maze of duct with a more efficient air path.
I totally gree on straightening out the air flow to get more air in, or help it flow better works wonders.
Here is mine:
F the haters
Seriously, I have no doubt that a switch from a non-CAI to a CAI...providing no restrictions are introduced in the process...will bring a power increase, however small.
But, somehow, hose-clamping HomeDepot plumbing components onto your Corvette seems a bit, well....I don't know, unprofessional?
There was a post on the CF several days ago, which showed PVC pipe used for an intake. The fabricator had hopes of garnering a few show points. I didn't say this on that particular thread, but if I were one of the show judges, I'd have been deducting points for it.....
Larry
code5coupe
I mean, really...if a plunger would add 5 horsepower, I bet you'd be against using THAT in the engine bay of a Corvette, too, right????
Some people, honestly......
Larry
code5coupe
