Dynamat installation
Old Sep 30, 2006 | 03:29 PM
bldavis11's Avatar
bldavis11
Default Dynamat installation
I am laying out plans for replacing my carpet in my 91 and wish to add Dynamat or a similar sound dampening material. I plan on matting the floor, firewall, and doors. I have a few questions for those who've done this before.
(1) What materials did you use and why? The Dynamat website confuses me with all of the options they have.
(2) Did adding the Dynamat, especially to the doors, make reinstallation of the carpet and door panels difficult?
(3) About how much should I budget for this?
Old Sep 30, 2006 | 03:37 PM
Brett Richmond's Avatar
Brett Richmond
Go to your local stero shop and check the prices When you see the prices you will have to pick your jaw off the floor. It does work but it is very expensive. All you have to do is cut it to fit the spot that it is going into, peel and stick. There are some other brands out there but they are all expensive.
Old Sep 30, 2006 | 06:55 PM
SSLT1KID's Avatar
SSLT1KID
you can get it cheaper online.
Shawn
Old Sep 30, 2006 | 07:18 PM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Here is a website you might find interesting.
http://www.sounddeadenershowdown.com/
Kevin
Old Sep 30, 2006 | 08:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I couldn't afford Dynamat
I installed B-Quite deadener and it was easy to install. So far all i have done is the rear cargo area and doors. I will do the rest someday
I bought mine off Ebay and used 50 square feet.
Old Sep 30, 2006 | 11:22 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Redid my inside, but Rino-lined first, then B-quiet, then JCWhitney, fire & sound insulation, then Mass-Back Carpet... improved 100%, did the whole interior firwall to rear..
Old Sep 30, 2006 | 11:58 PM
bldavis11's Avatar
bldavis11
Did you add any dampening material to the internal portion of the door assembly, or just the external portion? If you did the internal section, did it affect your reinstallation of the door pannels?
Old Oct 1, 2006 | 10:41 AM
AGENT 86's Avatar
AGENT 86
I did in and out and did not affect panel installation.
Here is a few pics
Old Oct 3, 2006 | 10:27 PM
bldavis11's Avatar
bldavis11
Can anyone help with product selection from Dynamat? These guys have so much stuff and I'm not certain what's for what. They don't go a great job explaining it in detail on their website.
Old Oct 4, 2006 | 05:54 AM
Joe C's Avatar
Joe C
i just finished adding sound deadening to my 85. i went with Damplifier Pro and Overkill from second skin audio. as a matter of fact, i finished last night.
try: http://www.secondskinaudio.com/cgi-bin/index.cgi
installation, while not hard, was a royal PITA. mostly because I'M SO FRICKIN' **** about these cars and anything i do to them. i spent a lot of time cutting/fitting/butting seams, etc. the hardest part was the drivers side firewall. i went with second skin audio mostly from what i read on this site - http://www.sounddeadenershowdown.com/ . lots of good information.
once i install my new power antenna, i can start adding my new carpet and trim...
BTW, it took 80 square feet to do my 85 coupe, and probably spent around 40 hours on installation.
Old Oct 4, 2006 | 07:25 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Yep, you want the EXTREME DynaMat.
Then have a look here cause ive allready done this job, lived to write about it too
http://forums.corvetteforum.com/show....php?t=1329197
Old Oct 4, 2006 | 02:58 PM
Thrak's Avatar
Thrak
I used Dyanamat Extreme. Blocks heat and dampens sound...
I bought 2 packs w/ contained approx 12sq.ft each. I didnt want to weight the car down TOO much, so I still have about 6sq.ft left over...
No problems w/ carpet/door installation, its very thin stuff. Also, w/ Extreme, no need to heat before application, like some of the other ones.
It works GREAT!
WOW Agent! Thats crazy how much you used! Have you thought about how all that extra weight is going to affect the door hinges over time? (maybe that stuff isnt as dense/heavy as Dynamat?)
Old Oct 4, 2006 | 11:28 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Very impressive job, Agent 86! Now I know why you added all the HP!
Did you make or buy those speaker baffles?
Old Oct 5, 2006 | 02:58 AM
Casethecorvetteman
I certainly cant see it being an issue mate.
Old Oct 7, 2006 | 04:14 PM
bldavis11's Avatar
bldavis11
Thanks for all of the repies. I'm looking into this some more and will delay my plans until I can read some more about this Second Skin material. Does anyone else have experience with this?
About how much did you guys spend?
Old Oct 7, 2006 | 04:25 PM
bldavis11's Avatar
bldavis11
Are you replacing the carpet as well? Which brand? Does it fit well? There are multiple threads on The Forum speaking poorly about the carpet kit from Mid America (it's outsourced from some other company).
One of my primary concerns is fit of the door panels and carpet over the new, thicker, floor and doors.
Old Oct 8, 2006 | 09:03 AM
AGENT 86's Avatar
AGENT 86
I made speaker mounts for front and back and i'm using factory covers all around.
To Dynamat installation
