really bugging me now!
Old Oct 8, 2006 | 09:22 AM
Waynester5.7's Avatar
Waynester5.7
Default really bugging me now!
I have been investigating an issue or 2 with my Vette. I mentioned in a previous thread that the car cuts out and the temp guage fluctuates wildly when put into D (drive - auto)..
The car was showing a code 15, which has been solved with a replacement cold temp sensor. When hooked to a laptop the engine temp showed a permanent 40 degrees and went no higher..that's now fixed.
Whilst connected to the laptop, the rpm tickover shows approx 750, but the dash tacho shows 1500 - 1800 rpm!! And when i kick down hard the tacho goes past 5000 rpm, past 6000 rpm and off the clock.
I have been loooking for an earth problem hoping that the temp guage and tacho and cutting out are connected in some way.
NB The temp guage is now permanently off the scale..(as in hot hot hot) except the car is fine.
I have no codes showing at all now, but when holding the car in drive whilst waiting at a junction for eg, it tends to cut out..not all the time, i would say 60% of the time.
I'm stumped..and it's frustrating to say the least. Any ideas....anyone??
Old Oct 8, 2006 | 09:33 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
BFH! Oh, you want good ideas, sorry.
Kevin
Old Oct 8, 2006 | 11:05 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
It might be worth your money to call Gordon Killebrew. I'll bet he could answer your question off the top of his head. See his site www.gordonkillebrew.com and good luck!
Also, if you want a copy of the manual from his class and one from Chris Petris' C4 class I will be glad to copy them and mail to you. Just PM me with your postal address. There is a lot of good info in these booklets but probably not exactly what you need for your specific problems.
Old Oct 9, 2006 | 09:22 AM
Casethecorvetteman's Avatar
Casethecorvetteman
That would be a bloody expensive phone call from his place Ron
To really bugging me now!
