Hood Struts Missing???
Old Oct 9, 2006 | 02:56 PM
AnniversaryJim's Avatar
AnniversaryJim
Default Hood Struts Missing???
I have an 88 Coupe (Anniversary - not that it matters here), and it has only one "strut" that holds the hood open (you know, the big long one with the orange thingy you push to the side to let it back down).
I have noticed however that there are 4 "pins" just near the hinge of the clamshell. They appear to accept some type of gas strut. Should they have 2 struts on them? My hood is quite heavy with just the one long strut and it does not "pop up" when I release the hood latch. Are these some type of lift assist struts that are simpy missing off my car?
Thanx,
Jim
Old Oct 9, 2006 | 03:34 PM
90Z51's Avatar
90Z51
It's only supposed to have 1. It's not supposed to pop up, you have to lift it.
Old Oct 9, 2006 | 04:07 PM
AnniversaryJim
So these mount points serve no purpose?
Old Oct 9, 2006 | 04:19 PM
90Z51's Avatar
90Z51
As far as I know. Maybe they served a purpose at the factory.
Old Oct 9, 2006 | 04:28 PM
CREWZIN's Avatar
CREWZIN
I have the two small gas stuts on my 87 hood. In fact I just replaced both of them ($15.00 each) with NAPA parts. They are just inside the headlights on each side. I thought all the clam shell hoods had them, but I could be wrong on that part.
Here's a pic of the one on the drivers side.
Old Oct 9, 2006 | 04:29 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
These exist even on the C4s that didn't get the strut (like my 1985). Seems the General was going cheap here...
Old Oct 9, 2006 | 04:38 PM
AnniversaryJim
That's them exactly. So would it be a problem to have all three (the two you have, and the one long strut that I already have)?
I'm no weakling, but lifting that hood while I'm still pulling on the release handle is a pain in the butt. I've been told that the hood should "pop up a bit" before you raise it to full extend.
Jim
Old Oct 9, 2006 | 04:40 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
My hood is quite heavy and it does not "pop up" when I release the hood latch.
While you do have to lift the hood manually, it should "pop" up about 2 inches when you release it. This is accomplished by the springs on the latch catches.
Larry
code5coupe
Old Oct 9, 2006 | 04:42 PM
AnniversaryJim
Maybe I just need to lube/adjust the springs.
Jim
Old Oct 9, 2006 | 04:44 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You might want to lube the latches a little it seems to help it pop up. I just pull the lever and close the door before picking the hood up.
Old Oct 9, 2006 | 04:49 PM
CREWZIN's Avatar
CREWZIN
I upgraded my long big strut to the gas charged replacement and I couldn't believe the difference. When I pull the lever the hood pops up about an inch, just enough to grap hold. As soon as you start to lift, the gas charged strut takes over and with the help of the two smaller ones, the hood pratically lifts itself...in fact I have to stop it from going all the way up by itself as it slams into the stops when reaching the vertical limits.
Old Oct 9, 2006 | 05:18 PM
AnniversaryJim
So you do have all three. I saw the short struts on eBay, but if I can get them at my local NAPA counter, I think that's better.
Would you happen to have the NAPA part number or anything?
I'll have to get some clips, as there are only 2 on the 4 pins. The others must have dropped off.
Thanx,
Jim
Old Oct 9, 2006 | 05:29 PM
Tstones's Avatar
Tstones
I had my hood open at a local car show, this guy came up to my car and told me I was missing the little hood struts on my 1990 Coupe. He started a big debate with another guy who told me there was nothing missing from my car.
Old Oct 9, 2006 | 06:48 PM
CREWZIN's Avatar
CREWZIN
Thanx,
Jim
NAPA Part number 819-5311.
Old Oct 9, 2006 | 08:07 PM
AnniversaryJim
Thanx, I'll order them up in the morning.
Jim
Old Oct 9, 2006 | 09:13 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
What differences did ya notice with the new Napa struts and what are the p/n's?
Old Oct 9, 2006 | 10:06 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I have all three struts on my `87. It does not pop up when I release the hood either
To Hood Struts Missing???
Old Oct 9, 2006 | 10:33 PM
lallend's Avatar
lallend
I just had a look at the Napaonline site and did a search on the Napa p/n 819-5311 and found nothing.
So I tried without the hyphen, 8195311, and found "Hood Lift Support, Attributes:Compressed Length:4.93" Extended length:6.38"
Sounds great so far, so what about the long gas-charged strut that ya are talking about? P/N and from where??
Old Oct 9, 2006 | 11:07 PM
John88RedVette's Avatar
John88RedVette
I have an 88 also with only one of the "small lift supports". Also, my hood does not "Pop" then the release lever is pulled. Normal?
Old Oct 10, 2006 | 11:07 AM
AnniversaryJim
Ordered struts from NAPA this morning. Best price I could get was $18.95. Must be California.
Jim
