I have an '86, my first vette and I haven't had it long. The rear hatch won't open - appears to be a lose connection to the solenoid. Anyone any idea how you access this. I can't figure it out.
If I remember correctly....crawl inside toward the rear hatch and inside the panel under the glass should be a thin metal wire. Give it a tug.
On that note, once you get it open, get a little lead bead fishing sinker and crimp that on the end so you can reach it easier while fishing (no pun intended) around under the rear shade for that little wire.
...or -
i crimped a 18-22 awg terminal lug on to the end of the thin metal cable. i then installed a 3/4 inch key ring -
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
The wire is there like everyone above mentioned.
I had an 88 with this problem. Once I determined it was the mechanisim I used a trunk opener from an oldsmobile until I could get the right part. NOTE- only the Corvette mechanisim has the manual release wire.
You have to remove the trim around the hatch to reach the wire. The handle for the top latch just pulls off. When you get off the trim, you'll see the wire. The relay is located under the trim.
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
You mean you have to remove the trim to reach the RELAY (and solenoid), not the pull-wire to pop the hatch. The wire (or cable) is accessible by reaching up under the pull shade just left of center as you're looking at it from inside the car.
When my hatch wouldn't open, the relay was fine. It turned out to be the solenoid, which has the pull-cable attached to it for manual release.
the relay in that general area is for the radio antenna. to make sure you differentiate that you got the right relay, have someone turn your radio on and off after you take the trim off around the latch.
pull the cable take off the rtim, and change the solenoid.
put a little lube on the mechanism before you bolt it down.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The hatch relay is next to the latch assy. The antenna relay is further outboard towards the fender. Never hurts to doublecheck though.
