Remove shade
Old Oct 17, 2006 | 07:55 AM
z88vette's Avatar
z88vette
6th Gear
Default Remove shade
Any ideas on how to remove my shade in my 88? I need to get to the antena.
Old Oct 17, 2006 | 09:06 AM
rons85's Avatar
rons85
The shade just pops out by shifting it all the way to either side and then pulling on it - a bit of leverage with a small pry bar will help, but be careful - it's all plastic. This will NOT do you any good for getting to the Antenna, however. The antenna is reached/removed from under the quarter panel, it helps to take out the left rear inner fender and go in through the wheel opening..
Old Oct 17, 2006 | 09:08 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Think of it as a giant toilet paper roller, remove it the same way you would the toilet paper roller. It's spring loaded.
You will need to remove it to gain access to the wiring for the antenna.
Old Oct 17, 2006 | 09:52 AM
Shawn_65's Avatar
Shawn_65
Scissors....
To Remove shade
