Need to replace C4 Dash, anyone ever do this?
Old Oct 20, 2006 | 05:02 AM
wilsonbh's Avatar
wilsonbh
Default Need to replace C4 Dash, anyone ever do this?
My 1988 C4 has a huge insightly crack that I can no longer stand to look at. I've never taken off the dash before. Has anyone done this and how do you do it? Is it easy? Hard? I'm considering all options right now. Possibly just throw a mat on it for $49 or go the distance and replace it for $500. I'd rather replace it.
Any advice to this rookie is helpful....
Bill
Old Oct 20, 2006 | 05:32 AM
RRT vette's Avatar
RRT vette
It is held in by metal clips and screws. There are two screws (maybe three) where the dash meets the windshield and a handful of screws under the dash closest to the steering wheel. They go longways across the dash bezels. After they all are removed you just pull it up and towards you with a little effort. You can check Ebay for the dash pad or a Corvette salvage yard.
Old Oct 20, 2006 | 06:02 AM
RRT vette's Avatar
RRT vette
http://cgi.ebay.com/ebaymotors/1984-...40133775QQrdZ1
http://cgi.ebay.com/ebaymotors/Corve...39261984QQrdZ1
Old Oct 20, 2006 | 07:10 AM
PAINTER MAN's Avatar
PAINTER MAN
I have never seen one but, they make a cap that fits right over top of the existing cover. I looks real good in the pictures. They cost about $100.
Old Oct 20, 2006 | 08:40 AM
AnniversaryJim's Avatar
AnniversaryJim
It's not that tough, I just had mine off in order to swap out the breadloaf (crash pad).
While you've got it off, take the time to vacuum out the dashboard, tighten any screws or connectors you see, and put a bit of white grease on the cable/connectors/spring/hinge on the defroster air gate.
Just my $.02
Jim
Old Oct 20, 2006 | 10:13 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I got one last year from www.vette2vette.com for $100 or so. I made the mistake of painting mine tan to match my interior. It reflected off the windshield something fierce! I also made the mistake of not prepping it fully before I painted it. Someone must have used Armorall on it at one time as the paint started to flake off shortly after I painted it.
Remove 3 screws on the left side above the instrument panel, remove the 2 screws at the defroster vents in the middle of the dash. While sitting in the passenger seat pull firmly toward you. It is quite easy to handle as it is very light.
Good idea to clean out as suggested above. Be sure to use some fabric dye/spray to recolor your fake speaker covers. For some reason the sun turns them blue over the years.
Old Oct 20, 2006 | 11:02 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Wow! Sounds easy!!
Old Oct 20, 2006 | 11:42 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Originally Posted by JrRifleCoach
Wow! Sounds easy!!
funny man
Old Oct 20, 2006 | 01:00 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Originally Posted by vinnies87
funny man
Old Oct 20, 2006 | 01:38 PM
Wayne88's Avatar
Wayne88
Originally Posted by RRT vette
It is held in by metal clips and screws. There are two screws (maybe three) where the dash meets the windshield and a handful of screws under the dash closest to the steering wheel. They go longways across the dash bezels. After they all are removed you just pull it up and towards you with a little effort. .
I took mine out for cleaning and there are no hidden surprises.
You will see all the screws that hold it on.
Old Oct 20, 2006 | 03:57 PM
skybolt31's Avatar
skybolt31
Is it possible to get a dash pad that doesn't have the speaker cutouts?
To Need to replace C4 Dash, anyone ever do this?
