Rugh Idle
Old Oct 26, 2006 | 08:36 PM
dheiser's Avatar
dheiser
Default Rugh Idle
I was washng off the engine at the local car wash and I must have got moisture in an 'off limits' area. i can't seem to get rid of the rough idle. There's a stumble on idle and a hesitation when accelerating from stop. What can I do to get it dried out?
Old Oct 26, 2006 | 08:37 PM
DarkMatter's Avatar
DarkMatter
'94 LS1? Is it a swap car?
Old Oct 26, 2006 | 08:50 PM
dheiser's Avatar
dheiser
I'm not sure what you mean by 'swap car' ? The LS1 was running great just before I washed it. I looked int he owners manual and it says 'don't wash in the V area just above the heads'. I certainly did that.
Old Oct 26, 2006 | 08:53 PM
STL94LT1's Avatar
STL94LT1
You got the optispark (distributor) wet. Hopefully, It will dry out.
Oh, if the engine is original. It's an LT1.
Old Oct 26, 2006 | 09:15 PM
dheiser's Avatar
dheiser
Thanks. It' s an LT1. Anything I can do to help the Opti-spark to dry?
To Rugh Idle
