antenna problems
Old Oct 27, 2006 | 11:33 PM
W89's Avatar
W89
Default antenna problems
my antenna is stuck up I was looking on corvette central and they showed a antenna relay ? wheres that located? thanks
Old Oct 27, 2006 | 11:55 PM
Sam Lam's Avatar
Sam Lam
An antenna that is stuck up does not indicate you have a relay problem. It suggests you have a broken ribbon on the antenna post. If you need more info on this, please advise.
Old Oct 28, 2006 | 09:36 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
There has been several recent posts on this antenna problem.
There should be some tips under the Tech Tips of the forum. Just click "Other" and go the Tech Tips.
It does sound like a broken mast ribbon. Before mine broke I did notice some issues in completely raising and lowering the mast. Had to basically retry several times to get the mast down or up.
The part can be obtained thru MAD or other vendors and I would suggest considering a bypass switch that is also sold particularly if you normally listen to your CD or tape player. The switch permits you to play each w/o raising the mast. And I get most local radio stations (wherever traveling) w/o raising the mast. Both parts you can probably get for under $50 and the installs are not difficult.
Old Oct 28, 2006 | 11:06 AM
AGENT 86's Avatar
AGENT 86
If the nylon rod is broken, you can get the part from GM. I paid about $25 cad for mine. Here is a little info on your antenna.
http://members.shaw.ca/agent86/Power%20Antenna.pdf
Old Oct 28, 2006 | 09:04 PM
Sam Lam's Avatar
Sam Lam
Agent86: I continue to be impressed with your data base on these types of issues.....wow!!!
Old Oct 28, 2006 | 09:49 PM
AGENT 86's Avatar
AGENT 86
It's easy after you scan a few thousand pages
To antenna problems
