I am in need of your help again. My 87 left headlight fails to rise to the occasion. the right one works fine.
What needs to be fixed?
Thanks for the needed input. Hopefully I can fix it and still drive for 3-4 more weeks before the dreaded winter sets in easternn Mass.
If you can hear the motor continue to run and the headlight isnt coming up its probably the gears. You can upgrade to the later style headlights which using bushings and a single gear and better wiring.
