Optispark-Should I replace ?
Old Oct 29, 2006 | 08:59 AM
bob-05's Avatar
bob-05
Default Optispark-Should I replace ?
I am a new member and would like to thank everyone for all of the valueable info on this site.
I just purchased a 95 that was sitting for about a year or so. The car runs good but had a leaking water pump that I just removed.
My question is, should I replace the distributor ? I have read that the optispark on the 95's was sealed better. Mabe disassemble and inspect it ?
Thanks,
Bob
Old Oct 29, 2006 | 09:27 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Any time you replace the water pump on an opti-spark engine, it would be foolish not to replace the opti. Wires also if they're original.
Old Oct 29, 2006 | 09:42 AM
fxgrnd38's Avatar
fxgrnd38
yep
Old Oct 29, 2006 | 09:48 AM
wake's Avatar
wake
You don't want to go through the hassle of removing the WP again later...
Old Oct 29, 2006 | 09:56 AM
bob-05's Avatar
bob-05
Thanks for the replies, I will replace it and the wires.
Old Oct 29, 2006 | 10:02 AM
scranage's Avatar
scranage
Hmmm, no one asked you how many miles on the car. Replace it if you like, but if it has low miles I bet that Opti is fine. Changing it and the wires is a lot more work ahead of you, and may give you no more than a little piece of mind.
Old Oct 29, 2006 | 10:17 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
I was initially going to ask about mileage, but you really can't put a price on piece of mind after 10 years, so...
Old Oct 29, 2006 | 10:23 AM
RRT vette's Avatar
RRT vette
My take: You can either leave the opti on and just replace the water pump and hope everything goes well in the future.
You can spend the money and replace the opti and have piece of mind, but any new product can fail at anytime.
If many miles on the engine. Replace the spark plug wires while your there at least and perhaps the spark plugs too.
Old Oct 29, 2006 | 10:29 AM
scranage's Avatar
scranage
I replaced my Gen1, passively vented Opti at 114K miles after a WP leak. Took it apart and there wasn't anything wrong with it, one small spot/stain near the weep holes, otherwise just fine. I'm still glad I replaced it, but mine had held up quite well. If this is a 50K mile or less car with a gen2 Opti, it is IMO likely a waste of time and money to replace a perfectly good Opti. If it has more than 50K, it gets harder to make that decision.
Old Oct 29, 2006 | 05:40 PM
bob-05's Avatar
bob-05
The car has 80k on it. Since I pulled it this morning I will be replacing it.
Any preference on brand ? Should I do the timing chain also?
Old Oct 29, 2006 | 08:50 PM
George Dickel's Avatar
George Dickel
I see no need to change the timing chain. 80k isn't that much mileage and you are looking at a lot more work to change it for very little to no gain. Spend your time and effort on cleaning and inspecting the rest of the car.
Old Oct 30, 2006 | 08:29 AM
Casethecorvetteman's Avatar
Casethecorvetteman
If it aint broke yet, dont fix it. It could last a long time yet. Youre no worse off if it does fail later on, if you can do the work yourself.
Old Oct 30, 2006 | 08:47 AM
SJW's Avatar
SJW
I'd go with either a new OEM unit, or a DynaSpark if you want the most peace of mind possible.
Definitely replace the plug wires while you're in there. Plugs are optional, but I'd do them, too unless they're fresh.
I'd also recommend you change all of the coolant hoses and serpentine belt while you have it apart, and drain and/or flush the entire cooling system (remove the knock sensors to drain the block).
Be well,
SJW
Old Oct 30, 2006 | 11:16 AM
LT1SPUD's Avatar
LT1SPUD
i just finished replacing the WP on my 96 this weekend...only 48K on the clock, so i left the opti-spark alone...if the opti does fail later, i can get the WP off in about an hour, so it won't be that big of a deal...
Old Oct 30, 2006 | 11:20 AM
Casethecorvetteman
Yeah the water pump isnt that hard to remove really, one of the bolts on the passenger side can be a pain, but its not really that much hassle.
Old Oct 30, 2006 | 11:37 AM
tarheelracer's Avatar
tarheelracer
You should put a Meziere electric WP in while you're at it.
Old Oct 30, 2006 | 11:40 AM
LT1SPUD's Avatar
LT1SPUD
actually, the worst bolt to remove is the middle one on the drivers side...there are a couple of rubber hoses routed in front of that make it a real hassle to get a socket secured on the bolt head....all the others are pretty straight forward..........
To Optispark-Should I replace ?
Old Oct 30, 2006 | 11:52 AM
bob-05's Avatar
bob-05
I am more fimiliar with the older corvettes. I pulled the pump and the Opti. The shaft on the Opti seems like it has some slop in it, but I don't have any experience with these.
I thought that the hardest part of the job was cleaning off the old gasket material on the engine block.
Thanks for all of the replies
Old Oct 30, 2006 | 07:15 PM
mikensc8's Avatar
mikensc8
I just did my water pump. While taking out the water pump it poored about 1/2 gallon of coolant on the optispark so I decided to take it out to make sure it was ok. In order to take the optispark out you have to take the crank pully/balancer off. I took apart the optispark and was amazed to find it completely dry!!! I replaced the rotor and cap, $60.00, put it all together and it started up and ran perfect. I had some issues in the begining, but they were resolved.
Old Oct 30, 2006 | 08:51 PM
Casethecorvetteman
HAHAHA!! Sorry mate!!! That is the one i meant, my car is right hand drive, your driver side is my passenger side
