Steering Woes
Old Nov 3, 2006 | 04:43 PM
petdoc's Avatar
petdoc
Default Steering Woes
My son's '84 C4 was really hard to steer when he bought it. He replaced the PS pump, but it did not help. Has anyone else encountered this? Could this be air in the lines? Does the Steering Rack go bad? It really takes a monster effort to turn the wheels. Thanks in advance, Lee
Old Nov 3, 2006 | 06:08 PM
scranage's Avatar
scranage
When you put the pump in, did you make sure to remove the plug that is installed in the low pressure line??? The pumps that come from AC Delco have a plug installed that can't be seen unless you look inside the line, it's real easy to miss it.
Old Nov 3, 2006 | 06:45 PM
petdoc's Avatar
petdoc
Thanks Scranage, He said he pulled a red plastic plug out before installing it. Does that sound correct, or should we go ahead and pull the low pressure line and check?
Old Nov 3, 2006 | 06:52 PM
aminnich's Avatar
aminnich
That sounds like the steering rack. Usually the first sign of failure is bad steering when cold, getting better as it warms up from use. Since there is a pump and a rack if one is eliminated the other is therefore likely.
Old Nov 3, 2006 | 06:58 PM
petdoc's Avatar
petdoc
Any recommendations on where to buy one?
Old Nov 3, 2006 | 07:07 PM
scranage's Avatar
scranage
Did he pull one, or two? There is one in each fitting. The one on the high pressure side is obvious, the other is not unless you look inside the line.
Old Nov 3, 2006 | 07:11 PM
aminnich's Avatar
aminnich
A good point indeed and lets hope it is just that. Steering racks are not that expensive, however the tie rod ends (outer of course) should be done at the sametime and the labor is what is expensive. A quality rebuilt rack, with credit for your old one, should be less than $200.
Old Nov 3, 2006 | 07:25 PM
scranage's Avatar
scranage
Yeah, or DIY with lotsa bad words, and then $100 alignment at the shop. If you left a plug in the low side, you will be able to loosten the high side fitting (at the top) a bit and run it without it spewing PS fluid. If it does spew, it must be the rack, but I've not seen one fail this way.
BTW I hate to tell you this, but if you left the plug in, the pump is toast.
Old Nov 3, 2006 | 07:26 PM
All2kool's Avatar
All2kool
Underinflated tires can make steering hard as well.
Old Nov 3, 2006 | 07:39 PM
petdoc's Avatar
petdoc
Hmmmmm, My son says he thinks he got the plugs. I guess since it is either a plastic plug in the line or the steering rack, we're gonna have to pull the pump (and or pump lines) either way. I guess we'll check it and if no plug, we'll proceed to remove the steering rack. There goes the weekend, eh? If this sounds like the correct approach or if there are any more pearls of wisdom from the forum, I am all ears. Thanks again in advance.... Lee PS any vendor preferences?????
Old Nov 3, 2006 | 07:43 PM
petdoc's Avatar
petdoc
YIKES!!!!!!
scranage's Avatar
scranage
I'd only go with AC Delco on the pump. My rebuild rack came from NAPA, so far so good. BTW, if you do get into the rack, follow the FSM, and make sure the steering is center locked. You'll need new tie rod ends as aminnich stated. You can count threads, but you'll still need an alignment. The job doesn't require a PHD, but it is a PITA. I still would bet on a plugged low side line, check by letting that high line loose first, if it doesn't leak all over, you must have a plug in there or a really bad new pump.
Old Nov 3, 2006 | 07:58 PM
petdoc's Avatar
petdoc
Why do these things happen on the same weekend the largest Bass Pro Shop in Texas has a grand opening 10 miles from my house???????
Guess what I wanted to do tomorrow????? I suppose I'll be grease monkey'n it instead.
Napa it is..... That's my pref too. Thanks for everything guys!!!!!! You have greatly helped me again. I just wish I had something to offer the forum besides the problems you guys always seem to solve!!!!! THANKS A MILLION !!!!! Lee
Old Nov 3, 2006 | 08:11 PM
petdoc's Avatar
petdoc
I do have a doctorate, but it is in small animal surgery not automotive engineering. So sutures and scalpels don't help here. I'll check the low side. I bet you are right. I'll let you know. PITA's: I am used to, almost expect it with these C4's, right? Thanks again....Lee
Old Nov 3, 2006 | 09:48 PM
aminnich's Avatar
aminnich
I would bet you get to go to Brass Pro tomorrow. It would be rare for them to have the rack in stock, maybe Mon or Tuesday. Maybe this will help:
https://www.corvetteforum.com/techti...=125&TopicID=2
Old Nov 3, 2006 | 10:11 PM
scranage's Avatar
scranage
Somebody has to take care of the kittah's and doggah's. Just do a quick check on that HP fitting, if it bleeds, order the rack and go to Bass Pro .
Old Nov 4, 2006 | 01:41 AM
Z51JEFF's Avatar
Z51JEFF
Its the steering rack.LT1 owners have OptiSpark,the rest of us have garbage racks that fail,they all fail from 84 to early 88 maybe.Ya got to love those G.M. engineers.
Old Nov 4, 2006 | 08:08 AM
petdoc's Avatar
petdoc
I think it is intentional by GM's plan. The correct terminology for it is "Engineered Obsolescence."
Old Nov 4, 2006 | 12:48 PM
plant7pugsley's Avatar
plant7pugsley
Default Racks
I believe the valve towers on the racks are one piece aluminum. They had numerous problems over cast iron. The biggest reason was premature wear. The valve o rings would cut into the side of the valve tower over time and you'd get blow by internal to the gear. Hence the fluid would be pumped around the valve instead of being directed to the side of the rack calling for power. The problem should go away when the fluid warms up. The seals will expand and fill in the wear grooves. Becuase of that, and the porosity inherent to aluminum die castings and stripped threads, GM got away from aluminum valve housing for 20 years. Only now have they gone back to an aluminum housing on the new GMT900 trucks.
You can buy sleaved rack housings where some aftermarket guy put a steel sleeve in the valve tower, this prevents the wear. However the failure mode for a improperly installed sleeve is quite severe. If the sleeve moves, it will block the hydraulic ports... leaving the gear in hydraulic lock... ie you lose steering.
I think GM's interim fix was different O ring compounds.
To Steering Woes
