What's the name...
Old Nov 4, 2006 | 09:59 AM
honda hunter's Avatar
honda hunter
Default What's the name...
What's the name of the piece or prong that connects the wires to the IAC and what's the name of the connector that connects the water temp switch wire to the temp switch itself? If you have part numbers and know where to get them that would be great.
Old Nov 4, 2006 | 11:42 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Any GM dealer should have them. Some carry them as leads or they may have the parts to assemble them. NAPA also carries some of this stuff. Mostly GM uses Metripak and Weatherpack connector assemblies.
Old Nov 5, 2006 | 09:42 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I just go to my local jobber. We look in his book of GM weatherpack connectors(Pico brand). It says what the connector is for and shows a pic of it with specs. A lot cheaper than GM
To What's the name...
