Is it difficult to apply hash marks??
Old Nov 7, 2006 | 05:09 PM
topgunvette's Avatar
topgunvette
Default Is it difficult to apply hash marks??
Old Nov 7, 2006 | 05:18 PM
LS6 Motor's Avatar
LS6 Motor
If it is the first time you have tried it, keep them wet, so you can move them around to get the exact location you are looking for.
Old Nov 7, 2006 | 05:29 PM
AnniversaryJim's Avatar
AnniversaryJim
Wet, wet, wet....
Just applied 28 large AAA logo's on 14 tow trucks. A little dish soap and water in a squirt bottle is great. Have a small squeegee available for smoothing out and pushing bubbles to the edges ( a window tint application kit has these). You have compound curves to deal with on the fenders, but the vinyl does stretch in all directions. If you have an edge that keeps popping up (wrinkle) don't stress... as the adhesive dries it will become sticky and it will eventually lay down. Don't over-work it, just take your time.
Good Luck.
Jim
Old Nov 7, 2006 | 06:07 PM
topgunvette
thanks for the tips guys, if i don't get it perfect can i re-apply it or is that not possible?
Old Nov 7, 2006 | 06:43 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
cant re do it. just take your time and test fit it a few times
Old Nov 7, 2006 | 07:07 PM
Poncho C4's Avatar
Poncho C4
Put them on wet! this way you can align them just the way you
want. also use a squeege.start from the center and squeege out
once you have them centered right and have almost all the water
bubbles out use a hair dryer put on warm and squeege untill
nice and dry and no more bubbles , the hair dryer is for the hash
marks to stick better.
Hope this helps......Poncho
Old Nov 7, 2006 | 07:11 PM
topgunvette
so is there stickness on the back of the hash marks or no?? so basically i get em wet align em to where i want them to be and squeege em to get bubbles out and blow dry until dry? should i use liquid soap as recommended by the seller?
Old Nov 7, 2006 | 08:22 PM
Poncho C4's Avatar
Poncho C4
Yes!.......I used 1 part soap 10 parts water. take your time!!!
Old Nov 7, 2006 | 08:42 PM
topgunvette
thanks for the info, ill let you guys know it goes once it arrives lol
Old Nov 7, 2006 | 10:11 PM
rick96cevette's Avatar
rick96cevette
I have heard that if you don't do a good job cleaning up after #2....you can get hash marks....oh wait that's skid marks....sorry
Old Nov 8, 2006 | 12:23 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
No you were right
Old Nov 8, 2006 | 03:03 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
experienced or not, always do it wet if you are able to.
You can't calculate accidents into your work. If that thing falls out of your hand and sticks good, you risk creasing it, stretching/warping it, tearing it ,etc and then are out a set of stripes
Ive done vinyl graphics on a few cars before with some auto-graphics guys and even the pros that do it all day long do it wet.
I found its a good idea to do it wet on the C4 hash marks because it doesn't quite go over the side of the hood curve correctly, so once you take the backing off you will need to keep smoothing and repositioning it to get it just right.
its not hard, just requires a steady hand and a good eye.
Took me 10 mins to get mine on from start to finish.
I went in to wash up, and drove off 20 mins later. They look great!
You don't need to blowdry it either.
Just squeegie the water and bubbles out the best you can. as long as it is wet you can peel it back to get any bubbles out that wont leave or readjust it if you knock it loose out of place. Once it is dry, its on there. Use a soft cloth the finish brushing it down and then leave it alone for a bit until the water dries out and its stuck down good.
Old Nov 8, 2006 | 03:05 PM
GIJoe's Avatar
GIJoe
Just as an FYI: the set I got from Ecklers said 4 drops of liquid detergent (dish soap) to 1 pint water.
I put it in a small 1 pint spray bottle we got from walmart or somewhere for $.50.
To Is it difficult to apply hash marks??
