Code reader link location?
Old Nov 8, 2006 | 02:55 PM
Huntervangolf's Avatar
Huntervangolf
Default Code reader link location?
Where is the code reader connector located?
Old Nov 8, 2006 | 03:03 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
by your right knee on the drivers side
Old Nov 8, 2006 | 03:07 PM
LS6 Motor's Avatar
LS6 Motor
I assume you mean the port for attaching a scan tool? It is located on the drivers side, above your right leg, just past where the carpet on the hush panel ends. This is where the port is on my 1991, and I don't think it had changed, but yours is OBD II, where mine is OBD I. There should be a cover on it, unless it is gone like a lot of them.
Huntervangolf
Ok am I blind or do I have to remove a panel, the panel with carpet under the dash?
Old Nov 8, 2006 | 03:19 PM
zo1boy's Avatar
zo1boy
I believe you are looking for the ALDL. It is located at your right knee as indicated above. There is a black tab covering it, so if you have black carpet, you may miss it at a glance. Shine a flashlight there, Youll find it. Then just pop the cover off.
Old Nov 8, 2006 | 03:36 PM
Huntervangolf
Okay I know I will be schooled on this but I'm not seeing it
Or do I have to be laying on my back?
Old Nov 8, 2006 | 03:50 PM
mk842766's Avatar
mk842766
Should be right where you took your pic.....seems to be missing???wonder where it went????
Old Nov 8, 2006 | 04:13 PM
zo1boy's Avatar
zo1boy
ooohhh, 1996...
Someone with a later C4 will have to chime in on this one, sorry.
Old Nov 8, 2006 | 04:25 PM
Idareu's Avatar
Idareu
Originally Posted by zo1boy
ooohhh, 1996...
Gimme a minute, I'll get go out and look at mine.
It's way back up in there.
Old Nov 8, 2006 | 08:55 PM
Huntervangolf
It's not there either. After digging somebody broke off the mounts and ty rapped way up under the dash . For awhile I thought I was loosing it!
Old Nov 8, 2006 | 09:10 PM
LS6 Motor's Avatar
LS6 Motor
That sucks, did they break the hush panel. These mount funny so it may not be broke. I have taken mine off a couple times so I can remove the panel completely, and I always have to think about it when I put it back together.
Old Nov 8, 2006 | 10:21 PM
Huntervangolf
Not sure. The whole reason I want to check codes is mine will get hot if I'm not moving (air flow over radiator). So I'm pretty sure that a sensor or relay is not working for my fans. If I turn on the A/C or defrost the fans come on. It looks like I got quite a few months to figure it out as it is suppose to snow here tomorrow night and the for a few days after. So I got the whole winter to figure it out I guess. Earlier today I was all excited to figure it out because I wanted to take it out for one last spin. But took out the 55 chevy instead. Wow what a difference in vehicles. Just got back from driving the 55 and it feels like driving a hurst compared to the vette.
Old Nov 8, 2006 | 10:33 PM
Idareu's Avatar
Idareu
Actually that is completely normal per JRZVette (post #16):
The primary fan is programmed to come on at 228*, the secondary at 235*, unless you're running the A/C in which case both will come on regardless of the coolant temp
http://forums.corvetteforum.com/show...ht=fan+cooling
Old Nov 9, 2006 | 02:47 PM
Huntervangolf
Well I let the vette idle when I got back from town till the temp got to about 250. The fans did not kick on. Then hit the defrost button and the fans came on and it started to cool back down. So I must have either a relay or a sensor out. But if I can make it through the day I got all winter to fix it . Hate having to put the vette away.
To Code reader link location?
