'86 Problem---Part 2
Old Nov 10, 2006 | 10:48 PM
rwolak's Avatar
rwolak
Default '86 Problem---Part 2
Obviously I pissed someone off because my first thread was closed.
Hey, take it easy gentlemen!!!! I didn't intend to come off with "having an attitude". If I did, I apologize!!!!
This is my first Corvette and when someone says "read up on the TV cable" when I'm trying to get the car running right, I thought they were yanking my chain. I'm not totally familiar with the acronyms you guys are using. I do have a Haynes manual so I'll take a look at it in the morning.
I've been on other forums and, as with this one, have found them all informative and helpful.
Thanx for your assistance!!!
Old Nov 10, 2006 | 10:54 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Problem is that it seems to bog down and be very sluggish on take off. After the first shift the motor picks up and seems to be running ok; however, I feel like it is still "holding back".
I suggest that you replace the fuel filter and clean the throttle body. Afterwards you can reset the TV cable.
I'd also pull the fuel sump and strainer. Clear the bottom of the fuel tank of debris and purge out all the old fuel.
Also check the FPR for sludge and function check.
3 years is a long time for fuel to make a mess of things
Old Nov 10, 2006 | 10:58 PM
rwolak's Avatar
rwolak
The fuel filter has been replaced but I haven't touched the throttle body. I'll try that first before making any cable adjustments.
thanx for the info.
Old Nov 10, 2006 | 11:02 PM
Pete K's Avatar
Pete K
I did not catch all of the first thread, but have you checked for a dragging/hung up brake? A friend had a e-brake shoe hang up and it took us a while to figure out why it felt sluggish.
Old Nov 11, 2006 | 07:28 AM
rwolak's Avatar
rwolak
Never thought of the e-brake. The car did sit for 3yrs. before I purchased it. Another thing to check!!
thanx for the idea!!
To '86 Problem---Part 2
