opti spark ???
Old Nov 13, 2006 | 02:19 PM
oldtimer's Avatar
oldtimer
Default opti spark ???
My 92 vette ran perfectly until I chaged out my antifreeze this AM. The car has developed a mid range miss. If I acidentally got that Optispark wet would it affect a miss only in the midrange. The car starts easily and runs fine until you accelerate mildly like pulling into traffic ,.then the miss occurs.If not the opti I'm guessing bad plug or plugwire. Any input would be appreciated.
I was busy doing other matters the last two days and tried starting and driving my vette this AM. It started and ran perfectly . Thanks all for your inputs. I dont drive my vette many miles here in Missouri during winter months but will replace some componets before next spring. Thanks again for you inputs they were much appreciated.
Old Nov 13, 2006 | 02:39 PM
runner140*'s Avatar
runner140*
Foregot who said it, probably everyone. " Look at the last place that you worked on or by". Did you get your Opti wet?
Old Nov 13, 2006 | 02:52 PM
SJW's Avatar
SJW
Did you get the Opti wet? Did you get the plug wires wet? Either or both of these could cause this problem to have coincided with the coolant flush. If you're lucky, it's only wet plug wires.
Be well,
SJW
Old Nov 13, 2006 | 07:03 PM
Shawn93PoloConv's Avatar
Shawn93PoloConv
My opti would do that (I have replaced 2 now) when I kicked it over about 2500 rpm or so. Mine got progressively worse until I could just get the car just over idle. Good luck.
Old Nov 13, 2006 | 07:05 PM
Digital Disaster's Avatar
Digital Disaster
Opti is toast.
Old Nov 13, 2006 | 08:53 PM
redwing76's Avatar
redwing76
Buy a code reader, you'll need it eventually......your problem could be many things, fuel, sensor, electrical, the list is endless.
Old Nov 13, 2006 | 09:11 PM
Greg Gore's Avatar
Greg Gore
Check to see which fault codes are stored. The Opti can be removed and disassembled for cleaning if it got wet if you don't wait too long to do it. The optical sensor is Mitsubishi and very reliable. The bearings will wear if allowed to get wet. The trigger wheel has 360 laser cut slots around its circumference which can plug with debris and corrupt the referrence. Double check everything you removed or unplugged to do the cooling system service
Old Nov 13, 2006 | 09:27 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Don't totally panic yet. I had similiar issues as you, and a miss in the exact same range. I replaced my plugs and wires, and everything went back to normal. Cross your fingers.
Old Nov 15, 2006 | 12:22 PM
oldtimer's Avatar
oldtimer
I'm going to replace my plugs and wires before fooling with that optispark. Changing those plugs on the drivers side looks like a tough job. thanks for your feedback.
Old Nov 15, 2006 | 12:31 PM
oldtimer's Avatar
oldtimer
Thanks to all for your inputs. I am going to change my plugs and wires first and then the opti if needed. I know its good for things to progress but is that opti an improvement over the HEI I'm not covinced. WE used the Mallory HEI in our late model and never had an ignition problem. I had an 85 Trans Am and chaged the HEI module once in 100,000 miles .
Old Nov 15, 2006 | 01:17 PM
redwing76's Avatar
redwing76
The opti isn't an improvement.........its bomb with a short, wet, fuse.
But by the grace of God its only a short term illness. 92-96 is a short time for such a good engineering marvel
Old Nov 15, 2006 | 03:11 PM
SK.LT1's Avatar
SK.LT1
Check the coil wire connection and coil wire.They have a tendency to corrode.
Old Nov 15, 2006 | 04:47 PM
Greg Gore's Avatar
Greg Gore
Good point! Now that you mention it mine had corroded connections and had been arcing inside the cap towers. The plug wires had not been plugged back in all the way during a previous owner water pump replacement and Opti cleaning and I discovered what was happening while taking it apart for timing cover seal replacement. The Opti's are easy to disassemble for cleaning if you get it wet by the way. While mine was off I decided to take a look at it and look inside because at the time of the sale the previous owner told me he had replaced it but that turned out to not be true, just cleaned the original a little and left two of the cap screws out while he was at it. Needless to say it's getting a new GM Opti along with another new pump in case his was really a rebuilt so I have a couple of spares I guess.
Old Nov 15, 2006 | 05:19 PM
RetroTA's Avatar
RetroTA
I had the same problem (Opti), It cleared itself up then it decided to puke on a road trip. After a $170.00 tow, I decided to go with MSD vented, Runs great now! I believe when these things start to act-up, Its over.
Its gonna go sooner or later. Just my 2cents.
Old Nov 16, 2006 | 06:29 AM
Greg Gore's Avatar
Greg Gore
I believe if you get it wet you really need to act quickly. Don't put it off or that will be the result. Needs to come off and come apart to clean internal components or it will get you. Keep Opti dry and and it's a pretty reliable system, as reliable as any other distributor based ignition.
Old Nov 16, 2006 | 08:42 AM
enventr's Avatar
enventr
I have read in this forum that a member had a similar problem.He used an air hose to dry it out.He lucked out in his situation.
good luck
To opti spark ???
