Antenna problems
Old Nov 14, 2006 | 08:53 PM
jay17's Avatar
jay17
Default Antenna problems
Is there any tricks or quick fixes if you antenna doesn't go down all the way. My makes it to the last inch and stops, 85% of the time.
Thanks for the info,
Jay
Old Nov 14, 2006 | 09:12 PM
copperhead55's Avatar
copperhead55
I had a similar problem except mine would not go all the way up.
I waxed the antenna and wiped it down. Then moved it up and down
numerous times then again waxed it and it cleared up the problem.
Whatever you do don't oil or grease the antenna it only allows dirt to get into the motor area and cause failure and replacement.
Make sure it is not bent at the bottom.
Good luck!
Old Nov 15, 2006 | 09:53 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Cleaning it may help, but it sounds like the mast ribbon may have lost a tooth or two.
Old Nov 17, 2006 | 07:29 PM
vetteman42's Avatar
vetteman42
I agree.....the PM is to use mineral spirits to clean the mast.
You can get a replacement ribbon for little over $20 and it's an easy install. Consider also a bypass switch that is available from MAD and similar suppliers. It permits you to use your tape player or CD without raising the antenna. I can get most of my local radio stations w/o raising the mast.
GOOD LUCK
SAVE THE WAVE
Old Nov 17, 2006 | 07:37 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Loose 2, then 4, then 8 , and ...well, you know the rest.
Unforunately for me, nothing helped mine - it's 21 years old. I tried oiling. cleaning,waxing,forcing the bugger back in. Finally it died. Had to cut the wires otherwise the battery would've died (stuck in the full up position, constantly tried to retract and I didn't want to disassemble the rear hatch carpeting)
I'll be buying a whole new assembly sometime this winter.
They aren't too expensive, around $150.00 for the whole shebang.
Cheaper elsewhere, I know.
To Antenna problems
