Stupid question about fan switch install
Old Sep 26, 2001 | 09:41 PM
jay17's Avatar
jay17
Default Stupid question about fan switch install
I have a manual fan switch I'm trying to install. I pulled the fan relays apart, how do you pull the wire out so I can put the other one in? :crazy:
Old Sep 26, 2001 | 11:35 PM
jfb's Avatar
jfb
Default Re: Stupid question about fan switch install (jay17)
Any auto store sells a crimp on wire tap that allows you to make connection to the green/white wire on the fan relay which if grounded by your manual switch will turn on the fan relay and force the main fan to run.
Old Sep 27, 2001 | 07:26 AM
vettenuts's Avatar
vettenuts
Default Re: Stupid question about fan switch install (jfb)
Download the instruction sheet from the Mid America site. It tells you how to hook it up. Not all years use a green/white wire, so be careful.
To Stupid question about fan switch install
