well here in Memphis to get through vehicle inspection you must have a working e brake. well the test is that it should hold the car when its engaged and the car is in drive and you push the gas. i don't think this test is fare to us but i guess i have to live with it. im not sure that it will ever work as good as they want it to but next time i go through i don't want them to have to just pass me even though my car moves quiet a bit. ive tried barely reving the engine and having it in neutral and they noticed both of my attempts. im not real sure how the e brake works on the vette but the mechanic that i took it to to get it adjusted the first time said that the e brake is set up different from most cars. i just got done with my inspection for this year but i want to know if there is anything i can do to fix it for next year
i guess the lady just felt sorry for me. the first time i went through it wouldnt hold at all then i took it to a shop to get them to adjust it then when i got to the inspection station it still wouldn't work good enough so i guess i looked sad enough or upset enough that she was like well ill pass you anyway lol. but i need to figure it out before next year i just figured i would see what i needed to do because i want it to work
