Electronic Spark Control Module
Old Dec 18, 2006 | 02:55 AM
Sirwilliam1229's Avatar
Sirwilliam1229
Default Electronic Spark Control Module
What is the purpose of the Electronic Spark Control Module?
Old Dec 18, 2006 | 05:02 PM
thebeerman's Avatar
thebeerman
It is a distributor.
Old Dec 19, 2006 | 08:15 AM
Sirwilliam1229
What are the signs that it is going bad?
Old Dec 19, 2006 | 09:14 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
The ESC is also called the knock module. It provides an interface between the knock sensor screwed into the engine block and the ECM. On earlier cars it was located near the evaporator housing (I think?) on later cars it was incorporated into the memcal in the ECM. When the ECM detects knock (pre-ignition), it will retard the timing to save the engine. This will sometimes result in a loss of power.
Usually a code will be thrown if it fails. If it fails "silently" your ECM will not be able to detect any pre-ignition due to bad gas, improper timing, etc. and you may damage your engine (unlikely for an unmodded engine in the short-term).
Old Dec 19, 2006 | 09:34 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Read this
http://members.shaw.ca/corvette86/El...%20Control.pdf
Old Dec 19, 2006 | 07:25 PM
RRT vette's Avatar
RRT vette
1989 Corvette right? The ESC module is located on the passenger side close to the blower motor and behind the fender gill. The module sends voltage readings to the ECM. There is also a knock sensor in the block on the passenger side. Anytime a knock is felt by the sensor...the module stops the voltage to the ECM and the ECM retards the timing.
You can test the ESC system by idling the engine to ~1,500-2,000 RPM and use a hammer (something thin and solid) and with about half strength..tap the block next to the knock sensor. The idle should drop if the system is working correctly. I think the link AGENT 86 posted states all of this and more.
To Electronic Spark Control Module
