I own a 86 corvette I was thinking about re-placing my engine or getting it re-built. What would be the best way to go and what kind of money are we talking to do either?
You can always go the cheap easy route and buy a ZZ4 crate motor from GM, and throw your intake and exhaust on it. Once you do that, the ZZ4 will NOT make the advertised power its rated at, nowhere close. But the engine is basically the same as the later C4s, and you'll just need a chip made and it'll be good to go.
Any other plans for a rebuild will entail serious thinking about engine modifications to make to up the power, unless you want to keep it stock.
Assuming you are going to drop the car off, expect to pay:
$1000 ro remove and replace engine
$300 for suprises. Radiator hose, powersteering hose, belt etc
$300 for tune up stuff. Cap, rotor, plugs, wires, fuel filter etc
$150 to completely disassemble to motor
$750 to completely recondition block
$500 to recondition heads
$400 for new flat tappet valvetrain
$150 to recon crank
$200 for balancing all components(rotating assembly)
$100 to rebuild rods
$50 to press off old piston and press on new
$100 Oil pump and pick up
$200 rings, bearings, gaskets
$500 to assemble long block
$200 to clean parts Intake, exhaust manifolds, timing cover, oil pan etc
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
As a rule of thumb you should double or triple your original estimate of both time and cost. Your actual cost and the time spent will fall somewhere betweent he original estimate and that higher figure.
I would vote for driving it until it dies and then spend the money.
but it's always good to have plan B ready when/if it goes. Heck, I've got a plan B hoping mine goes. With the potential machining cost, labor rates, your time if you're doing it yourself; it just seemed logical to me (cost wise) to swap an engine rather than rebuild it. Most crate engines come with a warranty which is important to some. PeteK hit it on the head with the costs, you'll also have to plan for incidentals. I've made so many trips to the parts stores during some projects for nitnoid stuff, it's made me sick. Just MHO. Good Luck
BTW if you fill out your profile, we'll be able to see your current mods and tailor our responses. I didn't know if you're looking for HP, reliability, daily driver, weekend warrior, etc...
