Digital Gauges change
Old Dec 28, 2006 | 11:26 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default Digital Gauges change
I usually keep the digital gauge display on my 93 set to "Coolant" (I guess I'm just **** about overheating). Lately I've noticed the display will switch to "Volts" or "Oil Temp" without my pushing the gauge button.
Is this common or is it a warning that something is starting to go wrong?
thanks
Old Dec 28, 2006 | 11:33 PM
CRV3TT3's Avatar
CRV3TT3
i have nothing to add to this thread except mine stay's on coolant and oil pressure all the time too...
but ive never had them change to the next setting in their own before.
Old Dec 28, 2006 | 11:50 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
The digital cluster has alot of issues. Wrong readings, screw ups, flickering once it gets old.
Old Dec 29, 2006 | 02:52 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Mine jumps to volts if the alt is not putting out enough.
Old Dec 29, 2006 | 11:43 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Like just after the engine fire catches before idle RPM is acheived.
This is normal. The gauge cluster will red flag the "out of normal" perimeters value and auto switch to that guage, until the value is back to normal.
Old Dec 29, 2006 | 12:08 PM
Muffin's Avatar
Muffin
I think that is a design feature. If a nonselected reading goes out of range it is brought up and flagged.
Old Dec 30, 2006 | 12:43 AM
Poncho C4's Avatar
Poncho C4
Keep your eye on the alternator
it's probably going bad!!!!
To Digital Gauges change
