86 VSS wire?
Dec 29, 2006 | 10:35 PM
86 VSS wire?
Where can I tap into the VSS wire on a l98? Can I tap into the cluster? Which wire? Thanks
Dec 29, 2006 | 11:07 PM
Not sure off hand. Do you have a FSM to refer too? Maybe someone else can supply better info.
Dec 30, 2006 | 12:35 AM
Run an advanced search in tech/performance for dakota digital (archives).
I've been in on several topics where this has been discussed in some detail
There should be a few that mention vss wiring and pin locations in the cluster. I'm too lazy to dig for it now.
Dec 30, 2006 | 01:11 AM
Tequilla~
Thanks for pointing me in the right direction
Update:
With a little digging,
I found the cluster pinouts here
D11 and D12 are both labeled as VSS wires ( In and out respectufully)
In hooking up navigation, which would be the "correct" VSS wire? D12?
D12 appears to be a pulse, D11 seems to be variable.
Anyone know colors for these?
Dec 30, 2006 | 02:32 AM
Only thing I can find while I'm at work. Perhaps it will help. I will check in my FSM tomorrow if needed. AGENT 86 did this for you. Gee he sure is nice.
http://members.shaw.ca/corvette86/Code%2024.pdf
