Dremel?
Old Sep 29, 2001 | 04:21 PM
rcolling's Avatar
rcolling
Default Dremel?
WTF...
I bought a Dremel specifically to cut the air lid on my car. I told the wife I would also get the tile grout, etc...
The basic kit comes with two cutting discs. I have cut approximately 1" and both discs are shattered. I have to be doing this wrong.
Can anybody point me in the right direction here?
Old Sep 29, 2001 | 04:27 PM
Hurricane_777's Avatar
Hurricane_777
Default Re: Dremel? (rcolling)
The discs that come with the kit are pretty bad. I would make sure that you have them secured properly to the tool. You'll also want to ensure that you apply a minimal amount of pressure when cutting. Once I got the hang of it, I was able to cut through my roommates aluminum downpipe on his Supra (Not done in revenge :D ) The plastic on the C4's are just about as hard!
If I'm not mistaken, they also sell some more robusts discs as accessories as well.
Scott
Old Sep 29, 2001 | 06:14 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Dremel? (Hurricane_777)
Make sure you aren't craching the disks when you put them in the tool. Since the direction of the rotation of the disk makes is the same direction for tightening the screw, you only need minimal effort to do this. I use my fingernail and have had no problems. Before doing it this way I cracked alot of disks. Now I wear them out instead. Get yourself a little tube of disks from Home Depot.
92TripleBlack
:flag
Old Sep 30, 2001 | 12:25 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Dremel? (92TripleBlack)
The cutting wheels that come with it aren't very tough. You can purchase others that hold up a lot better. I've cut through siding to mount garage lights and wound up using it to cut off about 30 screws that were twp long when I built an arbor in the backyard. They wear down but don't shatter like the ones that come with it.
Old Sep 30, 2001 | 01:30 AM
Irish's Avatar
Irish
There are two types of cut off wheels, one is thina nd brittle and breaks about the time you plug in the tool. The other type is made of fiberglass and does a great job.
Old Sep 30, 2001 | 03:39 AM
TJR's Avatar
TJR
Use a jigsaw with a fine-tooth metal cutting blade. Dremel, sheesh.
[Modified by TJR, 2:40 AM 9/30/2001]
Old Sep 30, 2001 | 09:14 AM
rcolling's Avatar
rcolling
Default Re: Dremel? (TJR)
Now you tell me. I have a jigsaw. I didn't realize they made blades to cut metal with it. (and now I have to do the tile) :smash:
Old Sep 30, 2001 | 09:59 AM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
I just put two blades together and they seemed to last a long time. The disks are so flimsy that even a little bend will cause them to shatter. :seeya
Old Sep 30, 2001 | 03:10 PM
rcolling's Avatar
rcolling
Default Re: Dremel? (96GrandSport)
Check the sig. Air lid is cut.
I got the jigsaw blades and they worked great for the long straight edges. The fiberglass cutting wheels work just fine on the Dremel. Don't shatter and cut well. Put the two together and time for :cheers:
Old Oct 13, 2001 | 10:21 PM
Big Mark's Avatar
Big Mark
I used my dremel with the flimsy little discs to trim off the shipping lip on my camaro's Harwood cowl-induction hood. One disc did the whole job. Wore it down to the arbor, but finished. :)
Old Oct 13, 2001 | 11:16 PM
jlbruggeman's Avatar
jlbruggeman
Default Re: Dremel? (Big Mark)
The discs are very brittle, if you are near a Black & Decker outlet store, you can usually find a tube of about 50 of them for under 10 bucks. If everything goes right, one will last quite a while, if you get in a hurry, they will disintegrate about the moment that you touch them to the work.
Old Oct 13, 2001 | 11:41 PM
dtorc4's Avatar
dtorc4
This is kind of ghetto (or, in my case, poor college student-ish), but I used tin snips to cut the mass of the lid off, filed the edges smooth w/ a metal file, then sprayed black rustoleum on it. It looks great (even though you can't see it installed). :cheers:
Maybe if you can tell your wife the dremel sucks you can return it now and get out of the tile thing. :D
[Modified by dtorc4, 3:42 AM 10/14/2001]
To Dremel?
