Header Prices?
Still need to verify the flanges are 3/8 thick..Hookers are 5/16
Every retailer I spoke to said comparison of fitment was a tossup.
Hedmans are looking better and better.
www.dmpolish.com
Charges $180, top quality coating...Does them one at a time, no produciton stuff.
The stock intake system on our L98's is, from my reading, quite limited to 4500 rpm for all practical purposes and is well shy of the redline of 5500 rpm. So by adding the headers you should gain the maximum bang for your buck and still be shifting at the correct rpm without getting into the redline. Safety and longevity!
The only draw back I've experienced is that the under hood heat is so intense it destroyed a good starter in six months and considering all of the tightly fitted plastics under our hoods, I will be paying for the ceramic coating for sure. You might also notice a more pingy sounding exhaust from under the hood, but it helps the permanent smile once you feel it.
thanks,
Am I correct in assuming that long tubes are the way to go or is that all that's available. Also, I'll draw on your collective experience...who makes the best ones for fit and performance?
14ga is thicker than 16ga steel...
Coated Hedman Elites, part number 68448 are also indeed 3/8" thick flanges.
here's a copy & paste from Summit site:
HED-68448
$336.99
Estimated Ship Date: 1/31/07
Brand: Hedman Hedders
Product Line: Hedman Elite Hedders
Header Material: Steel
Header Finish: Thermal coated
Header Style: Full-length
Primary Tube Diameter (in): 1 5/8 in.
Collector Attachment: Ball and socket flange
Collector Diameter (in): 3.000 in.
Tuned: No
Primary Tube Gauge: 14-gauge
Flange Style: Standard
Flange Thickness (in): 3/8 in.
Bolts/Studs Included: Yes
Gaskets Included: Yes
Reducers Included: Yes
Y-Pipe Included: No
Quantity: Sold as a pair.
Headers, Elite, Full-Length, Steel, Thermal Coated, Chevy, Corvette 1984-91, 5.7L, Pair
Ship date is 1/31/07, so it looks like they are out of stock again. When I ordered mine shortly before Christmas, they arrived 2 days later.
Ive been griping about $600 Hookers....CFI clued me into the Hedmans this morning..Flanges, pipes all look the same and much cheaper. May go that route, car doesnt know what brand the pipes are.
