Maintenance for low miles per year
1996 51K
I don't drive the car much nowadays. About 1500 miles per year. So I'm wondering how often I need to change the oil and what other maintenance schedule I should keep. They used to say change the oil every 3K or 3 months but I don't think the 3 months applies to synthetics.
Received 4,558 Likes
2016 C2 of Year
2015 C3 of Year Finalist
1996 51K
You never know when you change your oil too much, but you will know when you don't change it enough! Change it every 4 months, it will give you an excuse to drive it. And yes, I do go to an oil change place, but he is a friend of mine and he always looks over the underside of the car for me for problems. It's a small town & I trust him.
Location: One day you're a Comet...the next day you're dust... Arkansas
1996 51K
Once a year w/ synthetic.
I have a 1996 CE LT4 that I drive about 100-125 miles per month. I use Mobil 1 and have it changed when the car is inspected. I have read numerous posts and I believe once a year is fine with synthetics. If I was going on a long trip, I'd probably get the oil changed just for peace of mind. If you use a quick lube, I'd make SURE I knew who was changing my oil. We have ONE here that I trust. It's always the same guys, very clean and professional. I have a neighbor that is a lawyer. He took his 2006 BMW 750i to WalMart for an oil change. Yes, he took a $65K automobile to WalMart for an oil change. I was amazed that they had a filter for a BMW, but they did. So apparently he isn't the only person using WalMart for oil changes. I'm not that brave.
Mine are driven about the same. In 03 my 95 had 44k and now it has 51K. I say change the oil about once a year. If you have a garage to keep it in, that would be best. Get some of those bags from Mid America to keep the moisture out of the interior. Keep the battery on a tender to keep the charge up. Keep moth ***** around the car to keep out rodents.
I put just under 3,000 miles on my 93 coupe last year. I changed the oil at 1 year. I keep the car in a garage with a dehumidifier running all the time, not just for the car. I have a small lathe and milling machine(Bench top) and I need to control the humidity or everything turns to surface rust. Some people think putting 20,000 mile per year is better than 2,000? Everything will wear out sooner or later, take your pick. I prefer to drive it on nice clear sunny days and put it away when I'm done.
1996 51K
