Has anyone here replaced their Transverse spring suspension with the coil over shock suspension on an 85. Would like to know if it effects the stability overall and also if you remove the existing transverse leafs or leave them in place??
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I know you're a newbie, Don, so I'll go a little easy on you...
Use the Search function on this one, you'll find lots of comments on coilovers. You've been a member for several months, you should have seen more than one coilover thread by now..............
You remove the stock, transverse leaf springs, and coilovers shouldn't effect the overall stability of the car.
Good luck and welcome to the Corvette Forum.
