Another spark plug thread....poll
Old Jan 20, 2007 | 05:36 PM
Sprint7677's Avatar
Sprint7677
Originally Posted by onedef92
Plus, don't forget the C4's got more mechanically complex as they developed and the engine bay got more crowded with ABS, ASR, etc..
Your 1984 C4 did not have this extra equipment to contend with mechanically.
One good point for owning an 84
Old Jan 20, 2007 | 06:02 PM
Ttime's Avatar
Ttime
1993 LT1
(1) Engine - LT1
(2) Stock cast iron manifolds
(3) 3/8" universal, a 12" extension, 3/8" ratchet and a 5/8" spark plug-socket. Spark plug boot pliers.1' fuel line rubber hose and 1 1/2" rubber hose for # 8. Hi temp Anti seize, Dielectric grease and maybe an adult beverage.
A magnetic rod to grab stuff that falls and a flash light.
Old Jan 20, 2007 | 07:26 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Originally Posted by bighank
GM says NO antisieze compound as you will get too much lubrication on the plug threads and overtorque the plugs. I torque my plugs by FEEL as it is ALMOST IMPOSSIBLE to get a torque wrench in place with little clearance. Hand tight then just a little way with a socket wrench. BIGHANK
LargeHank I'm trying to disagree with ya but...
I'm looking at the FSM for the 1990 Vette and antisieze isn't mentioned.
Doesn't say use it, doesn't say don't use it.
It DOES say wait until the engine is cool before removing the plugs or the threads in the aluminum heads may be damaged.
(I've seen many post on this forum where guys are removing the plugs with the engine hot)
It's pretty common to use ANTISIEZE on sparkplugs going into aluminum heads.
If not, the electrolysis can (and will) cause the plug threads to lock in the plug hole and tear the softer aluminum threads when they are removed.
Antiseize should have no or very minimal bearing on torque on an 'open hole' thread.
I can't get a torque wrench on my plugs anyway.
Old Jan 21, 2007 | 01:54 PM
bighank's Avatar
bighank
Default antisieze compound
When I CALLED AC Delcos 800 # the "expert" there said that GM doesn't recomment using the antisieze compound since it will cause you to OVERTORQUE the threads on the plugs past the 11 ft# recommended. I haven't been able to use a torque wrench on the plugs in 95% of the plugs I've installed so good judgement prevails.
I usually hand tighten plugs and then go a little bit more with a wrench.
Old Jan 21, 2007 | 04:12 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I use antisieze on all my plugs.
Never had one come loose on it's own either.
I use antisieze on the plugs for aluminum heads and cast heads.
What the heck is it made for? The name gives a fairly strong hint.
I reckon if you have never pulled a plug that's been in for a year or two and have the plug hole threads come out with the plug then you'd believe there's no need for antisieze on them.
But what the heck, I got banned from a board for advocating pre-oiling an engine before cranking it up for the first time.
Folks laugh at me for filling up the oil filter before installing it when changing the oil too.
Funny thing, I seldom have trouble with my cars that are decades old and all those folks seem to have to purchase a new one every couple of years.
THen, it's MY turn to laugh at them.
The brightest bulbs in the chandelier often DO NOT work the help desk.
My FSM calls for a torque of:
Vin 8 ......20 Ft./Lbs
Vin J ......15 Ft./Lbs.
Hmmm.... did someone say that guy was an "EXPERT" ????????
Yep, me too. But the SECOND thing I do is antisieze the plug threads.
That happens right after I check/gap the little suckers.
Old Jan 24, 2007 | 12:30 PM
bighank's Avatar
bighank
Default removing plugs
One of the responses for removing plugs suggests a quick snap to loosen the plug. These plugs have been in there for 8+ years minus one that I checked about 2 years ago. Should I SNAP EM or try some rust penetrant FIRST and then just take a gradual amount of force breaking them loose? Don't want to REBORE the plug hole after I break off a plug. Last time I did this I was 16 and required taking the car firing on one less cylincer and with hissing every time the piston came up on a compression stroke. Haven't broken a plug since in last 45 years. BIGHANK
