Severe Power Loss
Old Jan 18, 2007 | 09:10 AM
zcool's Avatar
zcool
Default Severe Power Loss
what would cause power loss no power to the cockpit no headlights battery tested fine checked all the fuses on the side of the dash is there fuses somewhere in the engine bay 1984 crossfire injection 4+3 transmission
Old Jan 18, 2007 | 09:19 AM
94z07fx3's Avatar
94z07fx3
Have you tried jumpering the negative terminal from the battery to the engine block and the engine block to the frame?
With all that being out and with me knowing very little about 1984's I'd suspect a bad (open) ground strap.
Old Jan 18, 2007 | 10:33 PM
85 500 horse's Avatar
85 500 horse
Sometimes the obvious is the culprit. I'm sure you did, but have you checked the battery cables? Are they loose? Is there any corrosion?
Old Jan 19, 2007 | 07:36 AM
runner140*'s Avatar
runner140*
Toasted battery or maby a loose battery connection, for starters.
Get a hold of a digital multimeter and see what is hot and what is not.
Old Jan 19, 2007 | 09:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Also, look for a burnt fusible link near the battery. I don't have any schematics for an 84, but i bet there are a few links involved. Also check for poor connection at power juction block.
You may find some help from my 86 info http://members.shaw.ca/agent86/Power%20Distribution.pdf
To Severe Power Loss
