A/C Question
Old Jan 20, 2007 | 08:42 PM
Zoot Allures's Avatar
Zoot Allures
Default A/C Question
Turned on the A/C today and while it blew cool air and fogged up the windshield, there was a faint burning smell. Checked under the hood and could not pin point the source or general area. I had my A/C recharged in 2001. The car is a '94, and I don't use the A/C much, maybe that is the problem. Thanks for any input.
Old Jan 20, 2007 | 09:03 PM
SunCr's Avatar
SunCr
Try turning the outer hub of the compressor clutch by hand (engine off of course). It should turn with minimal resistance. If not, the compressor is probably on it's last legs. Otherwise, check the air gap between the outer hub and the pulley. It should be .020 inch. Too wide and it will slip. You can try to re-shim it, but if you have a burning smell, probably better to replace the whole assembly.
Check resistance of the clutch coil. Disconnect the harness and from the lead terminal to ground, it should be about 3.5 ohms (can vary with outside temp, but it should be above 3).
Check for refrigerant oil around the clutch assembly and on the hood above the compressor. If present, the compressor shaft seal needs to be replaced.
Check the blower motor wiring harness for discoloration at the connector.
Old Jan 21, 2007 | 11:38 AM
ronwc's Avatar
ronwc
Default ac smell
Check for heater core leak -
Old Jan 21, 2007 | 09:29 PM
bac22's Avatar
bac22
I'm leaning towards the compressor as well. Take a whiff of the compressor and see if it smells like burnt rubber.
Old Jan 21, 2007 | 10:02 PM
85 500 horse's Avatar
85 500 horse
The worst thing you could do to the A/C system is not use it. Lack of use causes the seals to dry up and deteriorate. Using it once every few weeks is all you need to do to ensure everything stays nice and moist.
That burning smell can be the clutch. If the A/C cycles often, you can be low on refrigerant. In cold weather, you should still turn on and use your A/C every few weeks. Simply add heat to the mixture.
Old Jan 22, 2007 | 09:54 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Foggy windshield is the first stage of the NIGHTMARE
Hope i'm wrong
To A/C Question
