Srs light help
Old Jan 21, 2007 | 09:33 PM
custombuilt15's Avatar
custombuilt15
Default Srs light help
So last week I lowered my stock 94. I disconnected the battery just for safety. When I was done I reconnected the battery. Now the service srs light and the service abs light are on steady. Also the radio and the hatch pop no longer work.
I checked the main fuse panel on the driver’s side and one small box on the driver’s side engine compartment. I have also searched the forum to find other posts about the srs light and could not find much on my problem.
Does anybody know if there is another fuse panel in the car somewhere?
Thanks in advance for your time and advise
Old Jan 21, 2007 | 09:39 PM
evmlarry's Avatar
evmlarry
Is it possible that some wire got pinched when you lowered it? maybe your ground is off or something? Just an idea, I'm probably wrong though.
Old Jan 22, 2007 | 10:55 AM
custombuilt15
good idea. i went and checked the wiring near the suspention and nothing appears affected.
Old Jan 27, 2007 | 10:38 AM
custombuilt15
Problem solved
A connector under the dash on the pass side had come unplugged I found it while troubleshooting a different problem
Thanks for everyone’s help
To Srs light help
