Starter question
Old Jan 23, 2007 | 07:20 PM
Normseven's Avatar
Normseven
Default Starter question
Can the soleniod be replaced on a starter? The past 2 Sundays when I drove the car, after I stopped at a store for 5/10 minutes when I went to start the car, it did not turn, but I heard a small sound, I turned key off and tried again and it started right up. On the first occurance I thought I might have not turned the key all the way, but the second time I was sure I had. Is this a sign the solinoid is going, or is it a battery issue. I bring that up as both times the car sat for a week in the garage and the temps here have dropped below freezing of late. The battery is 2 years old.
Old Jan 23, 2007 | 07:24 PM
tracktor312's Avatar
tracktor312
Hello the first thing I would do is check / clean all connections see if that helps. I just ordered a battery tender for mine.
Old Jan 23, 2007 | 07:57 PM
IRAraid's Avatar
IRAraid
Default Intermittent Starter
I had the same symptoms and looked up the possibility of a solenoid replacement. There are lots of threads if you 'search' for 'starter' and some describe how to rehabilitate the solenoid for small $.
I decided to replace the starter/solenoid unit as it really wasn't intended to be repaired (lots of crimps rather than bolts and screws).
I went cheap and got the assembly from Advance Auto for about $100.
The only hassle in replacement was one of the bolts - it was too close to get a normal socket on. I used a 1/4" drive socket, extension and adapter and bent the cat. converter heat shield a little.
It helps to remove the starter mounting bolts first, slide the starter forward a little, then remove the electrical leads. Of course, be sure to disconnect the battery first.
Total job was less than an hour.
Good luck.
Old Jan 23, 2007 | 09:16 PM
smurf5995's Avatar
smurf5995
If you are going to replace the solinoid, you might as well replace the starter at the same time. Advanced & O'Reillys sells both and the price is not that bad. In order to get to the solinoid you have to partially remove the starter anyway. To remove the starter you only have to move the exhaust pipe...sometimes you can manuever it past the pipe. Either way, if you have to move the starter and you are under the car...kill two birds with one stone.
Old Jan 23, 2007 | 11:57 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
If it's the regular'ol large round Cheby starter there's a really cheeeeep way to fix it.
Take it off.
Remove the solenoid.
Dissasemble the solenoid
Flip the 'button' around 180*
Reassemble starter
Put starter back on
Should be good for another 50,000 miles, er i mean smiles if it's a Vette starter.
Us "Po" folks been doing it this way for decades.
You guys do know 'bout this, right?
Old Jan 24, 2007 | 12:05 AM
Ironcross's Avatar
Ironcross
Take it off.
Reassemble starter
Put starter back on
He may not have a mountain to run it down and pop the clutch to start it!
"Po" folks is actually {right} correct, but yes you can buy a new switch and put it on the old starter.
Old Jan 24, 2007 | 12:13 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Wellllll... I can tell you never heard of this.
I should have just maintained the secrecy.
Here you go:
Yesss, Yesss, Yesss. You ALWAYS need to replace ANY starter that hiccups with a BRAND NEW one and preferably with the most expensive one you can find.
Then and only then will everything be 'right with the world', the planets will stay in correct alignment and the gravity of the Moon will be in constant and correct state of flux.
Anything other than a BRAND NEW starter will prove to be disastrous, will contribute to global warming, cause world wars and the universe COULD even collapse back onto itself.
It's best to NEVER take such a chance as it truly could adversely affect future generations not to mention the international economy.
ALWAYS use a NEW STARTER.
Old Jan 24, 2007 | 01:27 AM
Ironcross's Avatar
Ironcross
Here you go:
Where did I say that? It wasn`t me! Your barking up the wrong tree.
In fact I doubt if he really needed either the starter or a switch.
Old Jan 24, 2007 | 04:42 AM
VinceC4's Avatar
VinceC4
had the same problem on my '95..to me it does not appear as if you can replace just the solenoid.I put in a new starter, solenoid is attached and no more problems. pretty easy replacement, took longer to get the car high enough then to change out the starter. about an hour or so and it was done.
Old Jan 24, 2007 | 07:44 AM
kalister1's Avatar
kalister1
Your 95 uses a gear reduction starter, you will be suprised by the cost. Not cheap.
Old Jan 24, 2007 | 09:45 AM
thumper823's Avatar
thumper823
if you are interested in getting a good used starter, i can find one for you for under $100 as long as its not a zr-1
Last edited by thumper823; Jan 24, 2007 at 09:47 AM. Reason: interchange different between zr-1 and base
Old Jan 24, 2007 | 02:07 PM
Normseven's Avatar
Normseven
Take it off.
Reassemble starter
Put starter back on
I have never opened a Chevy starter. Thats the first time I heard you can flip the botton. I mentioned it to a Chevy guy I know and he said he never heard of it. I asked him to check with his son who works as a mech at the GM dealer. Anyway I will check it out myself, thought I more of the driver type.
Old Jan 24, 2007 | 03:07 PM
oldtimer's Avatar
oldtimer
QUOTE=tracktor312;1558647025]Hello the first thing I would do is check / clean all connections see if that helps. I just ordered a battery tender for mine.[/QUOTE]
check and clean first
Old Jan 25, 2007 | 10:18 AM
IRAraid's Avatar
IRAraid
Default Solenoid Bolt flip
Older GM solenoids could be repaired by turning the large lug (where the battery cable connects) 180 degrees after disassembling the solenoid. Newer GM solenoids can not.
When?
My '88 Jimmy's solenoid died and what a shock after opening the solenoid;
The dirty rotten scoundrels (GM) had ground off the side of the bolt head to prevent the quick/cheap repair (I bought the Jimmy new and no one else had ever worked on it).
Newer solenoids (like my '95 Corvette) are made differently but the contacts can be replaced (there are threads on how to do). I chose to replace the solenoid/starter assembly when the solenoid died.
To Starter question
